tractor [larger] sized metric nut and bolt assortment
   / tractor [larger] sized metric nut and bolt assortment #1
bryanhawaii
ford 1900
Just purchased a Japanese made Ford 1900 and replacing a lot of missing nuts and bolts and I am starting from scratch with a few American nuts but want to keep it consistently metric. I tried local sources and am now searching on-line sources for a handy assortment, but have only found smaller sizes . Can anyone suggest a reliable on-line source of tractor [larger] sized metric nut and bolt assortment , preferably with free shipping as I live in Hawaii??
Aloha and
Thanks in advance.............
   / tractor [larger] sized metric nut and bolt assortment #2
Aloha and
I know you said you looked locally but did you try commercial jobbers or actual fastener supply houses? I would imagine the larger cities would have such businesses. Even the small (non industrial) city I’m in has half a dozen dedicated fastener stores.
Good luck.
I'm in a small town on a small island in the Pacific and definitely not industrial so we have to import most things that you guys on the 'mainland' take for granted. but I will check for a fastener store here........................thanks for the tip.
   / tractor [larger] sized metric nut and bolt assortment #4
Fastenal is the largest volume brand.
   / tractor [larger] sized metric nut and bolt assortment #5
Just an FYI. On a Japenese
machine metric is not always the same as the rest of the world. There is a JIS standard that has different sizes and grades. Boltdepot.com has some good charts that show the differences. My Mitsubishi built Mahindra has ISO/DIN and JIS mix.
ANSI - American National Standards Institute
ISO - International Organization for Standardisation
DIN - Deutsches Institut f? Normung
JIS - Japanese Industrial Standard
* Indicates ISO standard.
   / tractor [larger] sized metric nut and bolt assortment #6
If your island has an Advance Auto Parts, try them for a metric assortment. It should take care of some of the smaller sizes. Around $10.00 if I remember correctly.
   / tractor [larger] sized metric nut and bolt assortment #7
The problem is that assortments tend to have every size you don't need and none of the sizes you do need. It would be a good idea to make an inventory of the required sizes and place an order with someone like Fastenal or McMaster-Carr for the necessary stock parts.
   / tractor [larger] sized metric nut and bolt assortment #8
   / tractor [larger] sized metric nut and bolt assortment #9
Gotta remember guys, the OP is in Hawaii.
   / tractor [larger] sized metric nut and bolt assortment #10
Needs to stop thinking "tractor" and start thinking "machinery" or "industrial"... His scope of search (tractor) is to narrow...
Dale
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A52141)
2016 FORD F-450...
2004 EAST GENESIS TIPPER TRAILER (A52141)
2004 EAST GENESIS...
John Deere LA110 (A50121)
John Deere LA110...
2018 FORD F-150 XL CREW CAB (A51406)
2018 FORD F-150 XL...
2012 Peterbilt 382 T/A Day Cab Truck Tractor (A50323)
2012 Peterbilt 382...
ATTENTION! PLEASE READ (A50120)
ATTENTION! PLEASE...
