tractor hydraulics locking up
   / tractor hydraulics locking up #1
alaskakubota
On my 2006 L3130 tractor I was having a problem with the hydraulics locking up. For example, I have two rear remotes (I can hook up to different attachments) and I had the backhoe hooked up to it. SO my backhoe lines plug into the quick connects. If I would be digging, it would lock up quite a bit. It would not lock up as much if I would run it at lower rpm's. The lock up I am referring to is if I start to dig and stop moving the lever, the tractor will sound like it is working and nothing will happen if I try to move the lever. I have to go to the remote lever that I have a bunjy cord on and release it, then push the lever the other direction, then pull it back to where it was. Sometimes it locks right back up and sometimes it doesnt. Like I said before, seems to happen more with higher RPMS.
Well the dealer ordered a new block for the backhoe which has maybe 2 hours on it.
Yesterday I was using the three point hitch log splitter on it and I have used it now for a couple of days after work. Now running it at 1800 rpms, it locks up with the splitter. If I release the remote lever and push it the other direction and then pull it back, the tractor doesnt seem like it is working, but as soon as I try to move the lever on the log splitter it locks up again.
The only way I can split wood is if I keep it under 1200 rpms. Then it will not lock up.
SO I know it is not just the backhoe, it has to do with the hydro on the tractor. I am guessing it is the pressure. I took it to the dealer and they dont work on tractors too much. They havent touched it since.
Sorry for the long post. Can someone give me some help on this? I have a bunch of wood to split and I want this to go away quickly.
SCAN FOR HAULING AND FINANCING INFORMATION (A51248)
SCAN FOR HAULING...
UNUSED INDUSTRIAS AMERICA HI100T HYD TILT LAND LEV (A51247)
UNUSED INDUSTRIAS...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2019 CATERPILLAR 330GC LONG REACH EXCAVATOR (A51246)
2019 CATERPILLAR...
