Tractor hydraulics and snow plow rams
   / Tractor hydraulics and snow plow rams #1
perik36
Westford Vermont
Massey 1736
If I adapt a truck snowplow for use on my tractor do I need to flush the rams before hooking it up to the remotes on the tractor? I know that the rams currently have a low temp snow plow hydraulic oil in them.
   / Tractor hydraulics and snow plow rams #2
I would and I did. Water, dirt, salt residue, and maybe even wrong type of oil. I also suggest you use automotive brake hoses to 'wire' it up because the rams are not used to seeing 2500 psi at a high flow rate. Brake hoses will slow it down a bit.
Thanks for the input, do you think a crossover valve would be a good idea too?
   / Tractor hydraulics and snow plow rams #4
Plow control valves have built in cushion (cross over relief) valves in case you hit a curb or something unmovable. A cushion valve would be recommended in between the rams and tractor control valve. Cushion valves are usually set at 3000psi to divert flow to the opposing ram when needed.
KennyD sells them online ( Hydraulic Valves - BoltOnHooks LLC )
Edit: I see above you were thinking of same
Thanks for the info
2010 Ford F-150 4x4 Pickup Truck (A51692)
2010 Ford F-150...
UNUSED FUTURE XJ3T 3TON 30" HYD THUMB CLAMP (A51248)
UNUSED FUTURE XJ3T...
10' WROUGHT IRON SITE FENCE (A51248)
10' WROUGHT IRON...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
UNUSED FUTURE SSJ430J WALK BESIDE JAW CRUSHER (A51247)
UNUSED FUTURE...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
