Tractor gets smaller home
   / Tractor gets smaller home #1
Wesdor
Western Illinois
JD 3720
Currently I house my tractor in a large machine shed. However, that should all change this fall when it gets to move into a new home. This is the site before anything started.
We have a 400' driveway and I took the top 6" of dirt off for use in the yard. Here is the tractor moving the dirt.
My brother and I put down geofabric so the rock wouldn't sink into the mud.
The first bite of dirt.
Here they are putting rock around the footing forms
The site is on a hill and doesn't allow for easy access by cement trucks. As a result they pumped the walls.
On Monday they began framing the house in nearly 100 degree heat.
By Monday evening, they had the lower level work nearly completed.
The decking was glued and then screwed into place.
Just to show priorities, the first wall up was where they tractor will be housed.
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2016 Kubota M5660SU (A50123)
2016 Kubota...
2015 Ford F-350 Dump Truck (A51691)
2015 Ford F-350...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
