Big Hammer
Bronze Member
- Joined
- Jul 1, 2009
- Messages
- 66
Hoping I'm posting in the right place here...
I recently bought a Satoh Buck; been working fine... until I added fluid to the transmission.
This may be a coincidence, not sure. I knew that the trans uses hydrolic fluid, as it has a FEL. I checked the level of fluid - too low. I added some #46hydrolic fluid (not too much) Went back to mowing, everything was going fine, no symptoms at all until it simply would not engage into reverse. Forward gears all working fine.
Did I use the wrong fluid? (only operated for 1/2 hr before the failure, after adding fluid)
Today I looked at the different lubricants at the farm store. They had something called 'universal tractor flluid' or something like that. Is that what I should have used? (rather than the #46 hydrolic fluid)
If so, did I do damage to the trans? Should I drain all of the fluid back out and start over??
Thanks if you can help.
What should I do ?
Mark
What should I do ?
Mark
