Tractor fatalities
   / Tractor fatalities #1
grapevine
I have investigated 2 separate fatalities in the last 4 years at landscape/nursery supply centers where loaders were equipped with material buckets to load mulch, but were also used for topsoil. Both operators accelerated out of the topsoil pile in reverse with the loaded bucket raised which caused the tractor to stand on it's nose, flipping the operators out of the seat into the path of the front wheel. Crushed skulls were the cause of death in both instances. Just an FYI. Know your tractors limitations and wear your seatbelt.
Grape
   / Tractor fatalities #2
Grape
Also be sure to use a counterweight/ballast box on the rear of the tractor.
   / Tractor fatalities #3
Most importantly put your seat belt on, lucky for me on that type of accident my tractor is 2wd so if the back end comes off the ground it isn't going to keep on moving (under power at least). I am probably one of the worst at not doing this while on flat level ground but I should. Lately I have been remembering to do this more often, just spent 3 hours tonight shaving topsoil off of a hill on the farm for fill in my yard, I had my belt on the entire time.
Also keep your loaded bucket as low as possible till it's dump time.
   / Tractor fatalities #4
Fill your rear tires or use tire weights, that will solve the problem.
   / Tractor fatalities #5
Not necessarily...
Even with filled tires, the weight in the bucket can overcome the weight in the tires. Filled tires and wheel weights might do the job.
As another poster wrote, if one is going to do loader work, put ballast on the 3PH. I like a ballast box, but a heavy box blade (500 pounds or more) will do the job.
   / Tractor fatalities #6
are tractors inherently unsafe or are people inherently careless???
I bet most of us here DONT use our seatbelts, but I also bet almost everyone here would not do loader work w/o a proper ballast and loaded tires.
   / Tractor fatalities #7
Grapevine, thanks for the reminder that trouble can happen and the consequences can be severe.
The point is to use all available methods to avoid trouble. If you use none, surely trouble will come your way sooner or later. The techniques, in order of my priority) appear to be:
0) instill in yourself and all around you who operate heavy equipment a "safety first" attitude and operational culture. Without this, all the rest is immaterial. Don't assume they know it's important to you... TELL THEM!
1) use seatbelt
2) don't get in a hurry
3) have "proper" counter weight for the equipment in use, either front or rear, loaded tires/tire weights/rear ballast/front ballast
5) have ROPS installed, in my case it is imbedded in a cab which provides further protection
6) when towing stuff, chain to draw bar and below rear axle of tractor.
   / Tractor fatalities #8
ALWAYS,ALWAYS WEAR YOUR SEATBELT! Even if you are only moving 5 feet. No one can anticipate an accident. You can have a rollover on dead level ground. It only takes a fraction of a second to BUCKLE UP! And it only takes a fraction of a second to get killed or injured.
   / Tractor fatalities #9
Today I made some blocks to hold up the FEL hydraulic cylinders and bucket out of the way while I'm working on the engine/front of the tractor.
   / Tractor fatalities #10
I thought about this thread while using my tractor this weekend. I have to say, I never really wore my seatbelt. Now I do!
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
2015 International DuraStar 4300 Johnston VT651 Street Sweeper Truck (A50323)
2015 International...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
2013 GMC Terrain SLE SUV (A50324)
2013 GMC Terrain...
