rlk
I have a gas MF 35 that I have had for about 15 years. I bought it used, and have used it extensively since buying it. The engine has developed a problem that has me stumped.
A week ago, after running it for about 3 hours raking the area around the pond with a landscape rake, the engine quit. Sounded like it was out of fuel. I messed with it for a few minutes, then tried to start it again. Started fine and ran for about 5 minutes then sputtered again like there was trash in the fuel line, or like it was giving out of fuel. This time I pulled the choke out a little, and it recovered for a few minutes, then sputtered again. Pulled the choke out again for a second or too, but this time it did no good - the engine quit.
Removed the gas cap to make sure there was fuel in the tank. Apparently the tank was pressurized because there was quite a sound as either air escaped the tank, or rushed in. Saw there was plenty of fuel in the tank, so removed the sediment (spelling) bowl. When I did this, the fuel gurgled a few times, then fuel ran out. Put the bowl back on, and the engine started fine. Made it to the shop and let it sit over night.
Next morning it started up fine and ran for a couple of hours before doing the same thing again. Engine sputtered some, I pulled the choke a few times, it recovered for a short time, then quit. Gas tank was pressureized. Removed the sediment bowl, gurgled again, then fuel ran out. Engine started up, but would only run for 20 seconds or so before cutting off again.
I decided I had trash in the fuel, and/or something was wrong with the sediment bowl assembly.
Found a replacement sediment bowl assembly. Took the old one off, drained the tank, then installed the new one. Also installed a new gas line to the carburetor. Engine started and ran fine for the rest of the day. I thought the problem was solved.
Next day, after a couple hours of raking, same thing happens again.
Talked to a Massey Furgeson parts person, and he suggested rebuilding the carburetor. Yesterday, I picked up a kit and rebuilt the carburetor. Today, after about 3 hours, the same scenario takes place again.
Finally make it back to the shop and let it sit outside while I talked to my neighbor. After about an hour, it started and ran long enough for me to get it into the shop. It might have run longer, but it was the end of the day, and I was tired of messing with it.
Originally I thought the problem was fuel related because pulling the choke out some when it sputtered would help it run a little longer. Now I'm not too sure.
Could it be the condenser or coil is getting hot and failing? These are not very expensive items, and are fairly easy to replace.
Could it also be vapor lock? Not sure how to fix a vapor lock problem on a tractor, but I used to have a Volkswagen that would not start when it was hot. Everyone said it was vapor lock - ended up trading it without ever fixing it.
Before doing anything else, I wanted to see if any of you had an idea what the problem may be.
