Tractor Dozer
   / Tractor Dozer #1
Nay
gauteng
none
hi
id like to know more about the tractor dozer if anyone could assist me as i am developing a manual on this useing saqa outcomes but there are a few thing that arent too sure about?
   / Tractor Dozer #2
What do you mean tractor dozer? Do you have a machine in mind?
Are you talking about a tracked machine with a blade? Or a wheeled tractor with a blade?
What do you mean by saqa outcomes?
   / Tractor Dozer
well id say both
SOUTH AFRICAN QUALIFICATIONS AUTHORITY
REGISTERED UNIT STANDARD:
Operate a tracked dozer
SAQA US ID UNIT STANDARD TITLE
262729 Operate a tracked dozer
ORIGINATOR ORIGINATING PROVIDER
SGB Civil Engineering Construction
QUALITY ASSURING BODY
FIELD SUBFIELD
Field 12 - Physical Planning and Construction Physical Planning, Design and Management
ABET BAND UNIT STANDARD TYPE PRE-2009 NQF LEVEL NQF LEVEL CREDITS
Undefined Regular Level 2 NQF Level 02 15
REGISTRATION STATUS REGISTRATION START DATE REGISTRATION END DATE SAQA DECISION NUMBER
Reregistered 2012-07-01 2015-06-30 SAQA 0695/12
LAST DATE FOR ENROLMENT LAST DATE FOR ACHIEVEMENT
2016-06-30 2019-06-30
In all of the tables in this document, both the pre-2009 NQF Level and the NQF Level is shown. In the text (purpose statements, qualification rules, etc), any references to NQF Levels are to the pre-2009 levels unless specifically stated otherwise.
This unit standard replaces:
US ID Unit Standard Title Pre-2009 NQF Level NQF Level Credits Replacement Status
116058 Operate a tracked dozer Level 2 NQF Level 02 24 Complete
PURPOSE OF THE UNIT STANDARD
The qualifying learner will be able to operate a tracked dozer by understanding the functions of starting, shutting down and operating procedures for the machine. Learners who master the applied competence described in this unit standard will contribute to the development of a professional community of Construction Plant operators.
The qualifying learner will be capable of:
• Demonstrating knowledge of the functions of a tracked dozer.
• Planning for work activities and prepare work area.
• Starting and shutting down tracked dozer.
• Operating tracked dozer.
• Transporting tracked dozer to and from site.
LEARNING ASSUMED TO BE IN PLACE AND RECOGNITION OF PRIOR LEARNING
It is recommended that learners entering into a study of this unit standard will prove competence in the following to enable the achievement of this unit standard:
• Communication at NQF Level 1.
• Mathematical Literacy at NQF Level 1.
UNIT STANDARD RANGE
N/A
Specific Outcomes and Assessment Criteria:
SPECIFIC OUTCOME 1
Demonstrate knowledge of the functions of a tracked dozer.
ASSESSMENT CRITERIA
ASSESSMENT CRITERION 1
The main functions of a tracked dozer are explained in terms of manufacturer's specifications.
The learner will be able to explain the main functions of a tractor dozer in terms of manufactures specifications
ASSESSMENT CRITERION 2
The operation of all major components is explained in terms of their functions.
The learner will be able to explain the operations of all major components in terms of their functions.
ASSESSMENT CRITERION 3
The applications of a tracked dozer are described in terms of earthmoving activities.
The learner will be able to describe the applications of a tractor dozer in terms of earthmoving activities.
ASSESSMENT CRITERION 4
All safety features and warning devices on the tracked dozer are identified, and their purposes explained in accordance with manufacturer's specifications.
The learner will be able to explain all safety features and warning devices on the tractor dozer in accordance with manufactures specifications
The learner will identify all safety features and warning devices on the tractor dozer in accordance with manufactures specifications
ASSESSMENT CRITERION 5
The maximum operating capacities are explained in terms of the designed tracked dozer capabilities.
The learner will be able to explain the maximum operating capacities in terms of the designed tractor dozer capabilities.
ASSESSMENT CRITERION 6
Warnings from tracked dozer indicators and gauges are explained according to manufacturer’s specifications.
The learner will be able to explain warnings from tractor dozer indicators and gauges according to manufactures specifications
ASSESSMENT CRITERION 7
Corrective actions are described or demonstrated in terms of neutralising warnings received.
The learner will be able to describe corrective actions in terms of neutralising warnings received.
The learner will be able to demonstrate corrective actions in terms of neutralising warnings received.
SPECIFIC OUTCOME 2
Plan for work activities and prepare work area.
ASSESSMENT CRITERIA
Sequence of operations is determined according to site operational requirements.
The learner will be able to determine sequence of operations according to site operation requirements.
Required equipment to perform the work activity is selected according to site operational requirements.
ASSESSMENT CRITERION RANGE
Equipment includes, but is not limited to:
• Machine attachments, personal protective equipment and safety signs.
Work area is inspected and prepared according to site operational requirements.
The learner will be able to inspect work area and prepare according to site operational requirements
SPECIFIC OUTCOME 3
Start and shut down tracked dozer.
ASSESSMENT CRITERIA
Pre-operational checks are carried out according to appropriate checklist.
The learner will be able to carry out pre operational checks out according to appropriate checklist
Daily and weekly operator maintenance is performed according to the appropriate post-operational checklist.
The learner will be able to maintain daily and weekly operator maintain according to the appropriate post-operational checklist
The learner will be able to perform daily and weekly operator maintain according to the appropriate post-operational checklist
Start-up and shutdown procedures are followed according to manufacturer's specifications.
The learner will be able to follow start up and shut down procedures according to manufactures spesifications
Tracked dozer is parked according to manufacturer's and worksite requirements.
The learner will be able to require to park according manufactures and work sites.
Tracked dozer hours are documented in accordance with company requirements.
The learner will be able to document tractor dozer hours in accordance with company requirments.
Tracked dozer maintenance and faults are reported in accordance with company requirements.
The learner will be able to report tractor dozer maintance and faults in accordance with company requirements
SPECIFIC OUTCOME 4
Operate tracked dozer.
ASSESSMENT CRITERIA
The purpose of the various controls is explained in accordance with their designed use.
The learner will be able to explain the purpose of various controls in accordance with their designed use
Functions of the various controls are demonstrated in accordance with the manufacturer’s specifications.
The learner will be able to demonstrate functions of the various controls with the manufactures specifications
Temporary safety signs are explained in relation to their use and placement.
The learner will be able to explain temporary safety signs to their use of replacement
Tracked dozer performance is monitored and corrective action is taken when necessary, in accordance with manufacturer's specifications.
The learner will be able to monitor Tracked dozer performance and corrective action is taken when necessary, in accordance with manufacturer's specifications
Tracked dozer is operated according to safe working procedures, manufacturer's specifications and earthmoving activity.
The learner will be able operated Tracked dozer according to safe working procedures, manufacturer's specifications and earthmoving activity.
SPECIFIC OUTCOME 5
Transport tracked dozer to and from site.
ASSESSMENT CRITERIA
Methods of loading a tracked dozer for transport are explained according to safety requirements, manufacturer's instructions and transport configuration.
The learner will be able to explain Methods of loading a tracked dozer for transport according to safety requirements, manufacturer's instructions and transport configuration
Methods of securing a tracked dozer for transport are explained and demonstrated in relation to lashing points and safety requirements.
The learner will be able to explain Methods of securing a tracked dozer for transport in relation to lashing points and safety requirements
The learner will be able to demonstrate Methods of securing a tracked dozer for transport in relation to lashing points and safety requirements
UNIT STANDARD ACCREDITATION AND MODERATION OPTIONS
• Anyone assessing a learner or moderating the assessment of a learner against the qualification must be registered as an assessor with the relevant Education, Training, Quality, Assurance (ETQA) Body, or with an ETQA that has a Memorandum of Understanding with the relevant ETQA.
• Any institution offering learning that will enable the achievement of this qualification must be accredited as a provider with the relevant Education, Training, Quality, Assurance (ETQA) Body, or with an ETQA that has a Memorandum of Understanding with the relevant ETQA.
• Assessment and moderation of assessment will be overseen by the relevant Education, Training, Quality, Assurance (ETQA) Body, or by an ETQA that has a Memorandum of Understanding with the relevant ETQA, according to the ETQA's policies and guidelines for assessment and moderation.
• Moderation must include both internal and external moderation of assessments, unless ETQA policies specify otherwise. Moderation should also encompass achievement of the competence described in the associated unit standards.
• Anyone wishing to be assessed against this qualification may apply to be assessed by any assessment agency, assessor or provider institution that is accredited by the relevant ETQA.
UNIT STANDARD ESSENTIAL EMBEDDED KNOWLEDGE
The qualifying learner will be able to understand and explain relevant aspects of the following:
• The Tracked dozer's operation procedures and main functions of all major components.
• The maximum operating capacities of the designed Tracked dozer capabilities.
• Statutory requirements including the Relevant Code of practice and Safety, Health & Environmental legislation.
• Worksite procedures.
UNIT STANDARD DEVELOPMENTAL OUTCOME
N/A
UNIT STANDARD LINKAGES
N/A
Critical Cross-field Outcomes (CCFO):
UNIT STANDARD CCFO IDENTIFYING
Identify and solve problems related to monitoring the performance of a tracked dozer during operations in which responses display that critical thinking is used for responsible decision making.
UNIT STANDARD CCFO WORKING
Work effectively as a member of a plant operation team with a civil construction team to achieve earthworks targets to required standard and within specified time frame.
UNIT STANDARD CCFO ORGANISING
Organise and manage oneself and one's activities responsibly and effectively in maintaining and monitoring the optimal performance and functionality of the tracked dozer.
UNIT STANDARD CCFO COLLECTING
Collect, analyse, organise and critically evaluate information about the functionality and performance of the tracked dozer in relation to the earthworks task to plan work activities and prepare work area.
UNIT STANDARD CCFO COMMUNICATING
Communicate effectively using appropriate modes of oral and/or written persuasion in dealing with all internal and external role-players to plan work activity, prepare work area and complete earthmoving task according to safety requirements.
UNIT STANDARD CCFO SCIENCE
Use science and technology to maintain and operate a tracked dozer in accordance with manufacturer's specifications and instructions in order to successfully complete a specific earthworks task.
QUALIFICATIONS UTILISING THIS UNIT STANDARD:
ID QUALIFICATION TITLE PRE-2009 NQF LEVEL NQF LEVEL STATUS END DATE QUALITY ASSURING BODY
Elective 65789
National Certificate: Construction Plant Operations Level 2 NQF Level 02 Reregistered 2015-06-30 CETA
PROVIDERS CURRENTLY ACCREDITED TO OFFER THIS UNIT STANDARD:
This information shows the current accreditations (i.e. those not past their accreditation end dates), and is the most complete record available to SAQA as of today. Some Quality Assuring Bodies have a lag in their recording systems for provider accreditation, in turn leading to a lag in notifying SAQA of all the providers that they have accredited to offer qualifications and unit standards, as well as any extensions to accreditation end dates. The relevant Quality Assuring Body should be notified if a record appears to be missing from here.
NONE
________________________________________
All qualifications and part qualifications registered on the National Qualifications Framework are public property. Thus the only payment that can be made for them is for service and reproduction. It is illegal to sell this material for profit. If the material is reproduced or quoted, the South African Qualifications Authority (SAQA) should be acknowledged as the source.
this is the saqa requirments hope this could be more help full
and tanx alot
   / Tractor Dozer
we are a training company we give courses on them im learning how to develop these cours materials so i thought it would be nice if i got some info form everyday users
   / Tractor Dozer #5
Maybe it's just me, but I think you are going to have to simplify the question, or questions considerably. And maybe narrow the scope of the question some.
YMMV:2cents:
   / Tractor Dozer #6
if you don't know how to operate one you sure don't need to be teaching someone
   / Tractor Dozer #7
Looks to me like an opportunity for a knowledgeable consultant to come over and assist you in the production of this course, or for you to make a trip here for some hands on instruction.
I am assuming that you are talking about what we call a "Dozer" or "Bull Dozer". Another good source of information for you might be heavyequipmentforums.com . They have a specific forum for Dozers
Good luck,
Tim
   / Tractor Dozer #8
Suggest you contact Barloworld for information. There is a possibility, however, that they already have a manual that covers the trading for which you are preparing your manual but there is a possibility they will let you familiarize yourself with a machine and it's operation at their training sites in Joburg or Capetown.
   / Tractor Dozer
thanx for all the help as i said that i am in learning and still need to learn alot but thanx
1998 INTERNATIONAL 4700 4X2 LIQUID TRANSFER TRUCK (A51406)
1998 INTERNATIONAL...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2008 VE 500 BBL FRAC TANK (A53843)
2008 VE 500 BBL...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
