Tractor deliverd sunday
   / Tractor deliverd sunday #1
dar in nevada
STAGECOACH NEVADA
MAHINDRA 2615HST
Well it finally got here late sunday evening. 2615hst with back hoe 3710 and fel ml106.Love it so far, only able to put 2 hours on it .Digging trenches with a back hoe is harder then it looks. This is my first time working a back hoe or a loader for that matter.Thats ok I look forward to all the practice I need.I do have one question though the loader lever seems to stick when operating the bucket wondering if this is normal or should it return when I let it go? seem more sticky after it warms up.Also it seems some times when lifting and dumping at the same time it will stop lifting and just dump,then start lifting again.I am not in any way complaining, the tractor seems very solid and Im very happy with it. This stuff may be normal or its just breaking in. will get some pic up soon.:)
   / Tractor deliverd sunday #2
Congratulations on your new piece!. Lots of fun ahead!
Regarding the loader lever, yes it should always return to center if you let go of the handle. Only exception would be the "float" position which is held in place by a detent.
The lift and dump action you describe is normal. The hydraulic oil will take the path of least resistance and if given a choice of raising the arms or tilting the bucket, all the flow will go to tilting, at least till the cylinders fully extend or you close that outlet with the joystick.
make sense?
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
1996 Chevy 2500 - Cheyenne Edition (A50515)
1996 Chevy 2500 -...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
UNUSED MOWERKING QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED MOWERKING...
