Hay Dude
Super Star Member
- Joined
- Aug 28, 2012
- Messages
- 18,735
- Location
- A Hay Field along the PA/DE border
- Tractor
- Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
Let’s say you are buying a tractor and you are comparison shopping.You ask opinions on TBN, talk to dealers, but do you check Tractor Data and Nebraska Tractor Tests? Do you read the tests carefully?
I have found Tractor Data to be the most indispensable piece of information when buying. Not all XX or XXX tractors test the same for hydraulic capability, PTO HP, Drawbar performance, Max Pull, Fuel used per hour, etc.
I am a disciple of Tractor Data and always check when I am comparison shopping. Trust me when I say to you that all XX or XXX horsepower tractors are NOT the same. Use their comparison tools on your “candidates“ before you buy!
I was comparing a Case-IH Puma to a Challenger MT545B and the Challenger had noticeably better test results in that particular model. Some manufacturers “under rate” their tractors. You think you are buying a tractor with 25 PTO HP and it tests out at 30 PTO HP. You’ll be surprised at what you find.
