Tractor can't get into gear
   / Tractor can't get into gear #1
Willsk
Harare
Massey Ferguson
I recently changed my hydraulic pump for my massey 240 , everything went well but i started the tractor and i can't change the gears, is there anything i need to check?
   / Tractor can't get into gear #2
Need more information do handles wobble around
Did you take shift cover off
Does tractor move at all
Did you put drive coupler back in with cutter pin, put in backwards will fall off
There is no wobbling and shift cover was never taken off. You can start the tractor but when you try to engage gears that's when it fails
   / Tractor can't get into gear #4
When you replaced pump did you put coupler back on it is on shaft out of gear drive on back of trans connects shaft to pinion assemble
John Deere 6420 Loader Tractor (A50514)
John Deere 6420...
UNUSED AGT QUICK ATTACH HYD HAMMER (A51244)
UNUSED AGT QUICK...
Kohler 30 Generator (LOCAL TOWNSHIP) (A50774)
Kohler 30...
CFG Industrial H15R (A50121)
CFG Industrial...
2016 Chevrolet Impala Limited (A50120)
2016 Chevrolet...
Kivel Q.A Pallet Forks (A50121)
Kivel Q.A Pallet...
