Tractor and Box Blade
   / Tractor and Box Blade #1
WillingtonPizza
Bronze Member
My wife and I are looking to by a tractor, B2410 or larger.
We need to be able to maintain a 1600 foot driveway that has a habbit of washing out when we get those hard Connecticut rains. We also have a large lawn and want to be able to use a brush hog to groom our trails and a camping area that the boyscouts use. Is there a small brush hog that can handle thick sapplings? Will a box blade be able to maintain our driveway or would we be better off with a pulverizer. We also do a lot of raking, my moto is if the soil is on top it must be top soil so rake it and plant more grass. Does a landscape pulverizer handle harsh treatment? How big of a tractor do we need?
   / Tractor and Box Blade #2
WillingtonPizza,
Tell us more about the size of your property. How big a lawn. How big the area to be brushhogged. Do you see loader work.
I do not have a pulverizer or boxblade so I won't comment on them. I have a B2910. I mow 3 acres with a 72" belly mower. I have another 8 acres of rougher grassland, brush and woods. I use a 5 foot medium duty brush hog to cut brush, long grass and cut trails on part of those 8 acres. I also do a lot of cleanup work with the loader.
All brush cutter manufacturers rate their cutters generically as light duty, medium duty and heavy duty. Strength, weight, cutting ability and price go up accordingly. A light duty is usually rated to cut 1" stems, but you will hear reports of people perhaps being able to cut slightly thicker stuff depending on what type of wood. Medium duty cutters aren't necessarily rated to cut thicker saplings, but I would try mine on 1 1/2 inchers. I suspect it may take more than one pass to cut that size. (I'll know for sure in about a month when I build a bridge over my creek to get to my really thick brush.)
As I said, give some more details.
Glenn
   / Tractor and Box Blade #3
WillingtonPizza, I have a B2710 and would recommend it or the B2910 for your use. I don't know what I would do without a front end loader and box blade, but have never used a pulverizer (I do use a tiller though to prepare ground for planting). How thick is a "thick sappling"? I've mowed down inch a half stuff with a light duty brush hog, but most, if not all, the manufacturers make light, medium, and heavy duty ones at least in the 5' or larger size. There are also 3.5' and 4' brush hogs available, but I don't know whether they are also made in heavy duty models.
Bird
We take care of about 30 acres and our finish mowing area is 4 to 5 acres. We currently have use of a very old yanmar tractor and use the bucket all the time so we know we would use one. We love to "groom" the woods.
   / Tractor and Box Blade #5
With that much land and finish mowing, I think you should be looking in the 2710 to 3710 range. The 3710 is the largest Kubota to take a belly mower. If you have hilly, rocky land and will be cutting woody brush, I think the brush cutter you should be looking at is a medium duty with a slip clutch.
Glenn
   / Tractor and Box Blade #6
It is really wise to purchase a loader with a smaller sized tractor. I would highyl recommend purchasing a loader even if you dont think you will use it. I guarntee you will.
   / Tractor and Box Blade #7
So you must be the owner of the famous Willington Pizza.
The food must be good, the place is always packed.The Eagle
next door must help your business/w3tcompact/icons/laugh.gif.
Someday when it's not so packed, and there is place to park I will eat there./w3tcompact/icons/wink.gif
Tom
Not the owner, kitchen manager, been there for 11 years now. Big change from my past job, general manager of a large day cruise line. Couldn't take the hours any longer or do the many things that I hated as a kid and love as an adult. (working on your own property)
   / Tractor and Box Blade #9
The 2910 has a lot going for it in additon to the added HP. It has extendable links on the 3 point and a couple of other nice features. A medium duty Bush Hog with chain guards and slip clutch will work nicely. A rake is inexpensive, and a tiller is wonderful for preparing soil for a nice seedbed. A pulverizer is of little use to me and a tiller does a better job. A box blade is the least expensive way to handle driveway maintenace, but a 1000# variety is not real cheap (Gannon) but is a long term investment and works well and is versitile in use. A Roadmaster type grader attachment is better, but that is about the only thing it is good for (and it works well).
If the Roadmaster grader blade is what I think it is (belly blade) I would like to get more info on the, does anybody know where I can?
UNUSED AGT 3 PT 82" ROTARY TILLER (A51248)
UNUSED AGT 3 PT...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2019 Dodge Challenger GT AWD Coupe (A51694)
2019 Dodge...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2004 CATERPILLAR 262B SKID STEER (A51246)
2004 CATERPILLAR...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51247)
KNOW BEFORE YOU...
