Traction with FEL and Backhoe
   / Traction with FEL and Backhoe #1
whodattractor
Texas
mf 2135
Howdy,
I have a bit of land that I need to maintain with a tractor. I found one nearby that is a Massey Ferguson and it looks like a 2135. It has a front end loader and a backhoe, but it's two wheel drive. I get quite a bit of water that builds up when it rains, and I'm wondering if the tractor would have enough traction going through mud being two wheel drive (but with a front end loader and backhoe installed to even the weight).
Thanks!
   / Traction with FEL and Backhoe #2
My guess is that it would be fine. I had an old 2 wd backhoe and it got around in the snow just fine.
   / Traction with FEL and Backhoe #3
Keep looking.
   / Traction with FEL and Backhoe #4
It has water filled rear tires and I thought the backhoe would help keep the back down, but wasn't sure. Thanks for the input!
   / Traction with FEL and Backhoe #6
It won't do well on hills. I'm not sure about mud.
   / Traction with FEL and Backhoe #7
Keeping the back down may not solve the problem of lack of traction in the mud. And eventually you find or make a rut deep enough that it bottoms out with all that weight. A lighter 4wd setup with R1 Ag tires all the way around would be more effective in mud.
   / Traction with FEL and Backhoe #8
It really depends on the hills you have, soils and the amount of weight you can ballast behind the rear wheels. If you can keep most of your weight on the drive wheels, you should be okay. Getter tooted analogy. If you can stack your weight to the rear, you should be okay. Too much on the front rear axle and you are in trouble.
   / Traction with FEL and Backhoe #9
I drove my 2135 through a creek with about 2' of water still sitting in it, didn't get stuck (but I don't have a FEL and a BH on mine). A 2wd with a FEL is ok if what you are moving is very loose material. If you try to move material with a FEL that's compacted that's where having 4WD really helps, but you can loosen the material with the BH then use the FEL to move it. That's my 30 years of FEL/BH experience working for a construction company.
UNSUED AGT MX-MRT14 STAND ON SKID STEER (A51243)
UNSUED AGT...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
Wolverine Quick Attach 80' Bucket (A50514)
Wolverine Quick...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
VOLVO EC300EL EXCAVATOR (A51242)
VOLVO EC300EL...
