Buying Advice traction on toolcat
   / traction on toolcat #1
KEVEN
TOOLCAT & FORD 1920
ON NEW TOOLCATS THEY MAKE REFERANCE TO HTC HYDROSTATIC TRACTION CONTROL IS THIS SOMETHING NEW? KEVEN
   / traction on toolcat #2
Keven,
The HTC offered by Bobcat refers to a "Hydraulic Traction Control" system which acts much like the limited slip differential in a pick up. It does help in low traction situations, but certainly isn't a locking diff.
   / traction on toolcat #3
The traction control sends the power to the wheel(s) slipping the least. It helps out a lot in most conditions. However, I still find myself spinning some wheels that are on very slick surfaces. It is not a locking differential and probably not as good as a limited slip differential.
   / traction on toolcat #4
It IS a limited slip differential. The TC axle uses the same technology used in pickup trucks and cars for many years. A quick internet search on thoery of operation is exactly how it works. It has clutches inside the differential that lock to transmit power to both sides of the axle. The drawback it that it can only transmit power to the non slipping wheel at the rate of torque available on the slipping wheel (plus some internal clutch spring preload). If there is not enough slipping wheel torque to transmit to the non slipping wheel, the axle will not drive. The front and rear axles are exactly the same.
AMG M 35 A2 C drop side 2 1/2 ton 6 x 6 truck (A50323)
AMG M 35 A2 C drop...
2006-2009 Ford 4x4 Pickup Truck Bed (A49461)
2006-2009 Ford 4x4...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2022 Ram Bighorn 2500 4X4 (A51039)
2022 Ram Bighorn...
2019 John Deere 8295R MFWD Tractor (A50657)
2019 John Deere...
