tstex
Platinum Member
Hello to All,
I saw the JD video on how to change the oil sent out by Tractorbynet. I really didn't learn anything new, but some comments made, I had heard previously too. "Add some oil to the oil-filter before you install it".
Well, I always added some oil to the top of the filter to lubricate the seal, but have never put any oil into the oil-filter before installing. I've changed the oil on 2 tractors, riding lawn mowers, six-wheelers and many other combustion-based engines that have oil filters. Decades afterwards, they still operate fine and I have never had an oil leak or lost compression of any significance. How can not adding oil to the oil-filer prior to install "starve the engine" for oil, that for any significant time would cause the least bit of damage?
Next, if you view the video, 2 things it does not say that are key [at least to me], is that you open the oil intake cap before you unscrew the drain plug. The video says to loosen the plug, then drain, then put plug back in, then change filter, then replace, then fill w oil. By not loosening the intake oil cap, a vacuum is created. The cap should be loosen for both the oil drain plug and filter removal.
Next, a more subtle point is to park the tractor on level ground. The video shows the tractor parked on a concrete shop flr [I hope it's level], but does not state it...I a lot of oil is changed on grass or dirt grounds and it's best it is level ground.
Regards,
tstex
Regards,
tstex
