TrackSteer w/ backhoe trailer
   / TrackSteer w/ backhoe trailer #1
ThomasD1
Hoping someone else here has a similar setup. Have a Case TR270 and I'm buying a Cat backhoe for it. Wanting to get a combo equipment / dump trailer and looking for recommendations on what length to get. Having issues with GVWR and actual cargo load capacities. Most 14K trailers are limited to right at or under 10K cargo capacity and it is getting tougher to find any breathing room for attachments etc. Looking at "Midsota" trailers now and see that they list dual 7K axles but GVWR @ 15.6K. Any comments?
   / TrackSteer w/ backhoe trailer #2
It sounds like the trailer manufacturer you're referring to is adding tongue weight into the carrying capacity. You may want to start looking for 16K trailers
I have a 14k GN, but acquired a 14k bumper pull in a deal when I purchased my TR320. I'd like to start using the BP to haul with after I convert it to a lunette / pintle hitch setup. Since I have a flatbed dually I plan on hauling any additional buckets or attachments on the bed to keep weight off of the trailer.
Just to let you know...I tried hauling a rental Kubota SVL75 in a BP dump trailer a few times. It sounds good in theory, but it's really hard to get the weight distribution right for comfortable hauling.
   / TrackSteer w/ backhoe trailer #3
Not all 14k trailers are built the same. I would be hesistant to put 10k on an appalachian trailer for instance. I have hauled 12k on my moritz though and had no reservations about it. This might sound nuts but make a spreadsheet with your trailer specs so you can cut through the advertising B.S. Comparing frames and cross memebers will highlight the strength differences. Some companies give you the option to upgrade to 8k singles to get a bit more capacity in the same trailer. Sounds like you need to step up to a tri-axle or a tandem dual set-up to get more capacity.
Do you have your class a cdl?
   / TrackSteer w/ backhoe trailer #4
As stated, not all 14K trailers are created equal.
I bought a brand new Texas Pride 14K deckover dump trailer in 06. According to their spec's. I should have been able to carry a payload of 10,000 lbs. First load I hauled weighed a little over 9000 (don't remember the exact number but less than 9500), it bent both axles in the middle of the tube. I put a 6000 lb. bottle jack under the axle while loaded and was able to straighten the tube. :laughing: I called the company, and they wouldn't stand behind it. Said that I had obviously overloaded the trailer. I replied, evidently I must have, but I didn't exceed your rating.
The axles, suspension, drums, and everything else were made in China. So I bought a pair of Alko axles and springs and put them under it. I haven't had a problem since, but could have bought a quality trailer and had change left over by the time I was done.
This is about the time I was learning that you don't always get what you pay for, but you'll always pay for what you get.
What ever you decide on regardless of GVWR, make sure the trailer was built with quality components. Your life, and others depend on it.
   / TrackSteer w/ backhoe trailer #5
I can vouch for Big Tex trailers. My GN is a 1998 model 20+5 w/ Dexter axles. It had been used as an "on the ranch only" trailer until I bought it five years ago. The brakes had been scavenged for other trailers. I put on new brakes from the backing plate out from etrailer, rewired it and gave it a paint job...new tires of course. It's hauled over 11k on deck more than a few times with no problems.
   / TrackSteer w/ backhoe trailer #6
Yep, Big Tex is good, PJ's a decent trailer too.
I've got a home made 14k trailer that's a good one too. Mostly because it has Dexter axles, and a Bulldog hitch (I'm going to have to do something about the jack though). I've still got the Texas Pride, and it's not too bad now, since I put $1800 in parts to replace the Chinese stuff.
Appreciate the feed back. Currently looking at 14-16K trailers now. Was intending on just a bumper pull, but don't feel quite comfortable with a possible 16K load on a bumper pull. Didn't want to have to remove my work boxes and rack in my pickup to accommodate a Goose neck hitch. But may have to now. Anyone out there with a 16K bumper pull? I've got an F-350 short bed so I'm rated just not sure if I'll be pulling the trailer or it will be pulling me. Also, any good ideas on a work box w/rack set up for a goose neck hitch? Thanks again.
   / TrackSteer w/ backhoe trailer #8
I am in the minority I know but I pull my 18,000# BP trailer all over and can't ever see going back to a GN. It is 32' long and has 3 6k axles under it. Pulls great behind my 2006 F350 short bed 4x4 extended cab diesel. Usually have the trailer right at 15,600# and the truck is 7,600#. No way I will go back to a GN and lose my bed space. I did upgrade the hitch to a 2.5" unit rated at 18,000#. Chris
Interesting. Thought 16k up trailers came with Pintle hitches. Did you have to change the trailer hitch for the 2.5" ball?
   / TrackSteer w/ backhoe trailer #10
No, it's a 2 5/16 hitch ball. The hitch itself on the truck is a 2.5" unit vs the standard 2" unit that everyone has.
Many of the newest diesel trucks come with the 2.5" hitches to take advantage of the capacity these trucks have. First was Ford then GM. Not sure if Dodge is using them yet.
I don't care for pintle. Too much slop for my liking. I have one that I must use at work but it seems hard or the trucks drive line bucking around like it does.
Chris
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
(4) 64" X 40" ALUMINUM POP-UP SIDE WINDOWS (A51248)
(4) 64" X 40"...
UNUSED CHERY INDUSTRIAL 7' - 10 DRAWER WORKBENCH (A51248)
UNUSED CHERY...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2011 JLG 6042 TELESCOPIC FORKLIFT (A51246)
2011 JLG 6042...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
