Trac Vac opinion please
   / Trac Vac opinion please #2
No experience for this model but I am the proud owner of a Cyclone rake really isn't much difference in price, Has a Honda engine will start first pull every fall after sittting all sumer. Also folds flat and will hang on wall. Goggle them they are super helpful, and will mail you a DVD if you are intrested, I would suggest the dual wheel option as it's get heavy if you pick up green grass!
   / Trac Vac opinion please #3
Cannot comment on this unit - price looks good seems to have the "right stuff" but I would go to TSC to validate what it has for hoses and attachments.
I have the Trac Vac unit and has worked well for 8 years.
Carl
   / Trac Vac opinion please #4
I have trac vac.had a 5hp one for 20+ years.worked GREAT.never did anything except change the oil. Then by accident I found a 11Hp one with electric start,bigger trailer,8" hose. Couldn't refuse it for the price. At High speed I think it could pull the worms out of the ground. I love it,love it,love it. Sold the old one to a guy down the street. Years ago the wife and I raked leaves here for what seemed like 2-3 weeks in the fall.Vowed to never go thru that again. Now we look forward to leaf and grass cleanup. Now there are a few on Ebay and very reasonable prices.look under trac vac
   / Trac Vac opinion please #5
That appears to be the same unit I have, but mine is labeled Craftsmen. I am sure it was made by Agri-Fab for Sears. I can't see it in the picture,but mine has a Chute also that lets you feed small branches in and chips them. It is a 9 HP version. It came with all required hardware including a generic box you mount over your mower discharge.
The vacuum works okay- in my case the Oak leaves and acorns that get mashed down or wet before I get them up may require raking to loosen them up. The hose set-up is easy enough to use but I end up having to make all right turns as a left turn will pull the hose off the attachment to the mower. The chipper works, but is so small that I'm not sure it is really worth it- the problem is not all the small branches will cooperate by being almost straight ;).
Unit itself has held up fine for the years ( I think 3 or 4) I've had it. Starts every time, no cracking or broken fittings, etc. I was storing it outside and a couple of times it surprised me by belching water out, but if you keep it covered that should be no problem. I do like that the sides are ridgid in that worst -case scenerio, I get scratches on it when vacuuming under trees and I would be concerned if I had cloth sides hitting the branches.
Hope this helps.
Thanks everyone for the info On the wensite they didnt give a whole lot of info on it so I called the local store and they filled me in on it. I cant order one online to be shipped to the store, but another store a couple hours away has one.
Anyone have the inside track on coupons with them? I was able to find one that was for online purchase only.
It would eb nice to have a coupon for anything off to offset the travel ill have to do,
Thanks All..:thumbsup::thumbsup::thumbsup:
Oh and I looked at sears they ahve it also slightly more money but they would charge to have it sent to the store..
   / Trac Vac opinion please #7
So you should go for others for making comparison , in this way you can get better idea of the market and your item and also about the quality. I think you should once go for Google / Shopping .
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2018 FORREST RIVER CRUISE LITE CAMPER (A53843)
2018 FORREST RIVER...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
