Towing with a Tundra - FYI
   / Towing with a Tundra - FYI #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
Before I brought my L4200 home, I was really worried about towing it. I never towed a heavy trailer before, so I was asking all kind of questions about towing and trailer brakes, etc, in places like here and RV forums. Most in the RV forums were fairly paranoid, suggesting not going beyond 80-90% tow rating, and using weight distributing hitches for anything over 50% rating. Add to that the seller telling me that towing the tractor with his 1/2 ton Dodge was scary (but then, it IS a Dodge). Silly me for worrying - after all, I have a Toyota /forums/images/graemlins/wink.gif.
Incidentally, adding margin to tow rating is rediculous IMHO - as an engineer, I can tell you that EVERYTHING is specified with considerable margin already, and something that could have significant litigous ramifications will have HUGE margins built in - you can trust me on that one.
OTOH, a friend of mine that has a Tundra told me that he towed a heavy dump trailer with two 1-ton pallets of stone recently and (other than taking a little extra time to get up to speed) it was nothing.
My tractor weighs ~3200#, plus 1300# for the backhoe, probably another 500# for the subframe mount, then whatever the FEL weighs, maybe another 1000#? My tandem-axle trailer weighs 2000#. I figured I was looking at somewhere around 8000#, which is a solid 1000# over the rated tow capacity for my truck. I use the factory hitch, with a standard ball - no weight distribution equipment.
I calibrated tounge weight by sitting a couple of my co-workers on my tailgate and measured the drop at the hitch. Two guys weighed in at 400-450 pounds or so, which resulted in a 3" drop at the hitch. When I loaded the tractor on the trailer, I set it such that the hitch drop was similar, giving me that same 400-450# tounge weight. This is about 5% of total load, which is half what is typically recommended, but it proved more than sufficient.
I won't say that you can't feel 8000 pounds behind the truck, since 0-20MPH times grew from 2-3 seconds to about 10-12 seconds, but other than that, it was virtually effortless. At higher speeds, once the motor could rev up, the truck actually accelerated fairly well, considering it was pulling 3x its normal weight - the Tundra does have an excellent motor. At 50MPH, it was like the trailer wasn't back there at all. The trailer did bounce the truck up and down a little when it hit bumpy areas, but I never got the feeling that the trailer was yanking the truck around at all. I have the off-road suspension package and BFG T/As run at 50psi - which probably helps too. Stopping distances weren't bad (electric trailer brakes work excellent) - I even had a panic brake situation when a minivan pulled out of a Duncan Donuts about 100 feet in front of me when I was doing about 50MPH - the heffer driving evidently couldn't see me or the 22ft long bright orange tractor barrelling down the road, since the cruller that was half stuffed into her mouth evidently obstructed her vision (I'm not making this up). In any case, I slowed the rig down with room to spare, though I did use two feet on the brake pedal /forums/images/graemlins/wink.gif.
In conclusion - towing with a Tundra at 115% of tow capacity is a piece of cake.
Jay
   / Towing with a Tundra - FYI #2
Before buying the Dodge 2500 I presently own, I had a 2000 Toyota Tundra. I used it on a couple occasions to tow an 18' "car hauler" I had, with a tractor on board. It did the trick but was overloaded with the 6200 lbs of tractor and 2100 lbs of trailer. (7000 lb rated trailer. I was overloaded in anyones book)
As far as that "don't worry about towing capacity, there's a built-in margin of error".... Tell THAT to the judge. There is the #1 reason why you use a heavier than required tow rig. As long as you're under the weight ratings, no worry. Push that limit, and get out the checkbook. What the Judge doesn't take, the transmission shop will.
   / Towing with a Tundra - FYI #3
HI Jay,
Thanks for your vote of confidence for your Tundra.
I also have a tundra,, although it's the base cab, 2wd, V-6, model year 2001.
Last fall, I was towing a utility trailer, with a lawn tractor,, and I dropped the tranny right out of it. I had used my truck for work, delivering equipment, and also towing my boat a few times in the summer. The truck had 72k miles when the transmission puked. I believe that all of the tundra's have the same transmission, but you can verify that with Toyota.
I would recommend that if you are going to tow something that heavy, make sure you change the transmission fluid and filter very often! I was told that if I had done that, I probably would have been ok. I must have overdone it, (very hilly around here) and when it let loose, it just broke. I had been having some hard shifts before hand, so I thought something was wrong.
I ended up with a used transmission with 13K miles on it. The shop I do business with said that he tried to get a rebuilt, but the demand has been so low for that transmission, that Jasper's doesn't do them yet. (probably a good thing in a way)
good luck with your truck, and keep on top of your service
intervals!
/forums/images/graemlins/cool.gif
</font><font color="blue" class="small">( Thanks for your vote of confidence for your Tundra)</font>
JFTR, I'm not recommending that someone go into the landscaping business and pull around 8000 pounds every day with a 1/2 ton truck - I was primarily just getting the thing home. My point is simply that my truck towed an overrated load well - it handled good, remained the boss of the two pieces 100% of the time, and stopped well. It did the job suprisingly and significantly better (based on other's reports) than some American-branded 1/2 tons, which I wouldn't have expected.
Good truck but fairly crappy gas milage. Toyota DOES use thin metal too, as I discovered recently. My wife hit my truck with hers (Chevy Tahoe) last weekend. Go ahead and laugh - I did. Her truck hit mine with an open door (Tahoe slid on ice in the driveway) - total Tahoe damage was the door got its botton corner bent up - about a 3/4" tweak. Somehow, however, that 3/4" piece managed to cave in the entire rear fender of my truck from the brake light to the back of the cab. Merry Christmas...
Jay
   / Towing with a Tundra - FYI #5
I have been tempted, as you were, to resort to knowingly towing an oversize rig. Two things stopped me.
1) I was told it was a buck a pound for overweight and you cannot drive it home from the place you get stopped.
2) I'm afraid my insurance company would dis-own me just when I need them most, know what I mean?
I just hire the fellow up the road to haul me with his flatbed.
Better safe than sorry.
I an no angel, but I don't publish my variances either /forums/images/graemlins/cool.gif
All the Best,
Martin
   / Towing with a Tundra - FYI #6
</font><font color="blue" class="small">( I'm not recommending that someone...pull around 8000 pounds every day with a 1/2 ton truck )</font>
Bummer. The Tundra is made right out the road from where I live. I'd love to have one, but have been concerned about how it would handle my 12,000 pound trailer. /forums/images/graemlins/blush.gif The inside secret word is that they will come out with a 1 ton version powered by a Toyota diesel in the next few years. I suppose I can wait until then. I have a feeling that I'd have warranty issues towing a 12k trailer with the current Tundra; even if it has the towing package. /forums/images/graemlins/crazy.gif
   / Towing with a Tundra - FYI #7
You can never have too much truck, there are all kinds of situations where you can have too little. I wouldn't consider a half ton truck of any brand for pulling any kind of weight. IMHO /forums/images/graemlins/grin.gif
   / Towing with a Tundra - FYI #8
And people try to tell me that I overload my BX 2200! /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
   / Towing with a Tundra - FYI #9
Jay
I pull my 4630 with loader including trailer around
7200 lbs with a 2002 ext cab 4x4 tundra. The trailer is a 20ft
goose neck. I never use overdrive, On a level highway
I run 59 to 60 mph at 26 to 2700 roms.I do this three times
a year to a hunting club in GA. 225 miles one way. No
problems so far.
crewcut
   / Towing with a Tundra - FYI #10
<font color="blue"> "I can tell you that EVERYTHING is specified with considerable margin already, and something that could have significant litigous ramifications will have HUGE margins built in - you can trust me on that one." </font>
Except that SCUBA dive tables have zero margin. Some things you don't want to push.
I'm glad that you got home safely.
- Just Gary
1264 (A50490)
1264 (A50490)
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A54313)
2012 INTERNATIONAL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A51694)
2005 Northwood...
