Towing the tractor, weight issues
   / Towing the tractor, weight issues #1
Highbeam
Super Member
South Puget Sound, WA
Kioti CK30HST
Folks,
I am in a jamb. I sold the bulldozer and am about to purchase a tractor/loader/box blade/brushhog/trailer. Yes it is a big deal for me.
The trailer will be a 10,000 lb GVWR car hauler type with electric brakes on both 5200 lb axles. 2' dovetail, all 6" channel frame and tongue. Bumper pull with W/D hitch. The trailer weighs 2300 and is very adequate.
The truck that I need to keep is a full size chevy, half ton, pickup with a 350 V8, 3.73 gears, and auto tranny. I am an RVer so I have experience pulling trailers and this pickup does very well as equipped with trans temp gauge, overload springs, and the heavy duty factory tow package. The truck is "rated" to tow 7000 lbs with a GCWR of 12000. This same truck offered today with the same tranny, rear end, and a smaller engine has a 13000 GCWR. My truck weighs 5500 unloaded. Would love a one ton dually diesel but it ain't in the cards.
The tractor is a Kioti DK40 with loader. I calculated 5000 lbs for the tractor. The implements together weigh about 1300. I can haul the implements seperately but would like to haul at least a 750 lb brush hog attached.
So my total trailer weight will be right at about 7300 which is 300 over my tow rating but puts me at 800 lbs over the GCWR of my 98 pickup and right at the GCWR of the modern day version. Truck's axle weights, hitch weight, and LTC tires are within ratings.
I want to be a weekend warrior tower and run the tractor once per weekend over a 45 mile one way trip on pretty major, nonsteep, low altitude, roads at about 60 mph. I can leave the implements at the property in my shipping container.
Bottom line is that I am a bit, 7%, high on the GCWR. Any opinions on whether this is reasonable?
   / Towing the tractor, weight issues #2
Joe, from what I've seen in my years of RVing; just a wild guess of course, but I'd bet well over 50% of the RVs you see on the road are over the rated GCVWR, and by more than 10%, too. Now I certainly will NOT recommend that anyone do that, but if it were me, I wouldn't worry about it as long as you have good brakes on both truck and trailer and experience with pulling trailers safely. Those ratings are the "recommended" weights, and the truck manufacturer doesn't know whether you're going to be in the mountains, flat land, winding roads, straight roads, hot weather, cold weather, ice, snow, rain, or drought. So they have to come up with a "rating" for all purposes. So in my opinion if you know you can control and stop it safely, and you know you aren't overheating the engine or transmission, you're good to go.
   / Towing the tractor, weight issues #3
I don't know which transmission you have but have you modded it for trailer towing? I do that on all my GM vehicle to get rid of the soft shifts that are the cause of much slippage and wear and heating.
Vernon
   / Towing the tractor, weight issues #4
I'll second what bird said. You're keeping an eye on temps, have experience hauling, and aren't doing anything crazy. Unlike the guy towing a backhoe with a Ranger, you will most likely be fine.
The Ranger lost his truck, trailer, and backhoe when he jack knifed the trailer down a slight decline coming off a bridge. The truck was totaled, the trailer upside down, and all you could see of the backhoe was its bucket sticking up out of a ditch. How in the world he thought he could tow that load with a Ranger is beyond me... actually, how he got that load moving is beyone me.
   / Towing the tractor, weight issues #5
Yep see it all the time, trucks over loaded.
Dont be that guy!
Do the right thing, not only will everybody be safer
you'll also feel better knowing your doing it right!
I use a singel rear wheel F350 PSD manuel trans.
My RV 10000, tractor & trailer right at 10000
Surely you can cash that 1/2 ton in on a nice used 3/4
and keep the cost down.
It's way better to have to much truck rather than not enough,
I always have enough, but never to much!
By all means get yurself a bigger truck!
Gene
   / Towing the tractor, weight issues #6
<font color="blue"> Bumper pull with W/D hitch </font>
Are you using the equalizer hitch and bars? Using them will improve handling greatly.
   / Towing the tractor, weight issues #7
Your familiar with towing -- soo --- The question is; will I be involved in a situation where the excess weight may void my insurance ??
Think it's your call!
Egon
   / Towing the tractor, weight issues #8
Do-able? Yes... Safe? Probably.... The truck can handle it? Most likely... The D.O.T. will understand your situation? Probably not.... If you're over weight ratings on the truck, the hitch, the trailer, the tires, or any combination of these things, the long arm of the law can and (from my experience) will extend their warm invitation to appear in front of 'Da Judge".
I'm not trying to rain on your parade, just offering to lend you my umbrella....
   / Towing the tractor, weight issues #9
Keep an eye on your rear tires, make sure they are properly inflated.
If you have rear drums on the truck make sure they are properly adjusted, depending on tounge weight the front end may get light.
If you are going to pull the trailer a lot, switching over to a synthetic or synthetic blend for the rear diff might be a good idea.
Dave
The rear drums from chevy are in need of regular adjustment and they are done at every other oil change when I rotate tires.
The weight distributing hitch is the official name of an equalizer type system with spring bars to distribute the tongue weight over both truck axles. This is done to prevent lightening of the front end and a few other things. A few hundred pounds of the tongue weight gets put on each axle. This is very common in the RV world. The tongue weight of less than 850 is not much really, split in half that is 425 on each axle which should make for a nice smooth ride.
In a wreck, the lawyers can get you nomatter what. I won't live in fear. My registered weights will not be exceeded. I am not interested in turning this into a legal debate as I know they can go on forever. I will not knowingly drive an unsafe load, I do not feel that merely exceeding a manufacturers rating makes a load unsafe. Please understand why I am not interested in going down the legal road.
The 4 speed auto tranny in my truck has not been modified, I do not use overdrive to tow. The ATF has been flushed and filter replaced every 50,000 miles. I use mobile 1 synthetic lube in everything including the transmission and rear end. Rear end lube changed every 33000. The truck is in great shape.
As I said, not interested in buying a bigger truck. Let me ask you this.... If a one ton truck was 7% over the GCWR would you still tell the guy to get a bigger truck, maybe a dually? Many folks don't give a half ton truck enough credit, I say the class of truck doesn't matter as much as the ratings. FYI, the 3/4 ton version of my truck has 500 lbs less towing capacity than my half ton as written in my owner's manual.
I will use the 4 chain and ratchet binder method plus one for the loader bucket.
Sounds like the general consensus is that the truck is capable, the trailer is capable, if the driver is capable then give it a try.
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A53426)
2020 CHEVROLET...
2018 Mercury Verado 250HP Outboard Boat Motor (A51694)
2018 Mercury...
2006 Acura RL Sedan (A51694)
2006 Acura RL...
Landhonor RSB-14-80W, 80" Rock Bucket (A52384)
Landhonor...
Star Industries 66in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
Star Industries...
