i'm wondering what sort of loads you can expect to haul with a tractor and still be reasonably safe. this isn't something i've ever really had a need to consider before, but i have a situation where i am considering building a small dump trailer that can be towed behind my tractor (a jd 770).
this is for a location where you cannot have vehicles, so bringing a dump truck in as needed is out of the question. there are no roads in - virtually everything is brought in by boat / barge. you can bring in vehicles for temporary construction use, but that's not cost effective for repetitive use due to the transportation cost. it's also only a gravel carriage trail road system, so even a full size dump trailer would be out of the question because it would be difficult when meeting other vehicles and pedestrians. you have to watch out for the occasional hikers or bikers along with utvs and golf carts, so you need to be in control of your vehicle.
i'm thinking about a 4' x 6'-6" dump trailer with 15" to 18" sides. i don't have an exact figure on the weight of it yet as it's something i would build as i get to it and as i come across the ideal materials at the right price, but it's bound to be around 1000lb before i am done. i'm planning on a dual axle just to help in balance since my tractor is pretty light. the bare tractor is around 2100lb, and with a loader, operator, and fluids it must be 3000lb or so. a body the size i am looking at would easily hold a yard of materials, and probably a bit more.
can i expect that this would tow fine? my biggest thought would be downhill grades (there aren't many, and they aren't long or extreme) and whether you would experience a case where the trailer starts driving the tractor because of the weight behind you. i'm looking at a 1mph-5mph speed range, and i have the transmission to keep me from freewheeling and gong too fast, but is that enough?
