towing a tc
   / towing a tc #1
dylan
ottawa, canada
Toolcat B series
i know this has been discussed before ... but i'm really looking for a solution for getting my tc around when it is dead. I do a lot of snow removal and it often dies in the middle of the road. Yesterday, it died blocking two lanes of traffic! I ended up getting a loader and skidding it to the side of the road but I really need a better solution.
I previously built metal skids for under the tires so I could drag it home but if one of the skids grips the road, the wheels counter-rotate and move the skids so they are no longer effective or they get jammed up in the wheel well.
Has anyone come up with a way to disable the hydro system so the machine will free wheel? This should be a standard feature ... a neutral setting. Any input would be greatly appreaciated.
My next plan is to build a "car dolly". Jack up the tc and place all four wheels in cradles and only have the trailer wheels touching the ground. The drawback to this idea is that is take a while to get setup especially while blocking traffic on a busy road.
   / towing a tc #2
Good luck. I spent some time talking with a trustworthy BC mechanic and he said there isn't even consensus from BC Corporate on how to do this. I guess one needs a helicopter with substantial lifting capability.
Obviously, there's an opportunity for some enterprising individual to invent something. The dolly idea is the best I've heard so far.
   / towing a tc #3
Dylan & Spudgunner,
There is a procedure for properly towing a disabled TC. There is a "special" set of bolts that when installed will completely "disconnect" the drive system. From what I have read in the procedure you will have zero control after installing the bolts so make sure you are on level ground and have the wheels blocked. Needless to say, there is quite a bit more than installing the bolts. My dealer gave me a copy of the the procedure which is not with me at the moment. If memory serves me, the bolts were in the range of $30.00 to $40.00. I have been warned that towing without installing the bolts can cause major issues.
Tim
   / towing a tc #4
Dylan & Spudgunner,
Tim
Man, I'd gladly pay that much for the bolts. I'll pass this by my mechanic and see if he can get a copy of the procedure and p/n. If so, I'll post all the info I can. With regard to damage incurred while towing (sans bolts, presumably), my mechanic mentioned this as well. Actually, he specified towing no more than 16'. I guess that's supposed to be enough to get it on a trailer.
   / towing a tc #5
how about something like this:
   / towing a tc #6
Spudgunner,
If you send me a reminder I will find the procedure and send it to you. I believe it is at home and I'm currently in the office.
   / towing a tc #7
Dylan & Spudgunner,
Tim
Seems kind of dumb that Bobcat doesn't include a set of these and the procedure with the Toolcat so you have it WHEN you need it.
DEWFPO
   / towing a tc #8
DEWFPO,
While I'm not positive, I think the procedure may actually be in the manual under the heading of Towing. When we were having a "issue" with one of the TC's, I believe the Service Manager e-mailed it to my phone while I was on-site of the break down and quite a few miles from the shop.
Tim
   / towing a tc #10
I know (as per my Wife) it's in the manual for the B series. I have been told that it may not be in the manual for the C & D series. I'll see what I can do about "sharing"... Possibly a scanned version to post.
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
2012 John Deere 7230R (A51039)
2012 John Deere...
FULL ACCESS TOOL BOX (A50854)
FULL ACCESS TOOL...
71056 (A49346)
71056 (A49346)
2010 SHOP MADE WINDMILL TRAILER (A50854)
2010 SHOP MADE...
