Torque settings for Y385
/ Torque settings for Y385 #1
Johnny P
Bronze Member
Brittany, France
"Shire badged" Jinma 284LE
It is now time to rebulld my Y385 after getting a replacement crank. Can anybody help with the following torque settings?
CRANKSHAFT PULLEY TO CRANKSHAFT
MAIN BEARING CAP BOLTS
BIG END BOLTS
OIL SUMP TO ENGINE BLOCK
BOTTOM SUMP PLATE TO SUMP
FLYWHEEL TO CRANKSHAFT
TIMING COVER BOLTS
CLUTCH HOUSING TO ENGINE BLOCK
CLUTCH HOUSING TO GEARBOX
Thanks,
Johnny P
/ Torque settings for Y385 #2
From my YangDong Y85 operations & maintenance manual:
Cylinder head bolts 160 Nm (~118 ft-lb)
The following are listed for the Y485, but it's a Y85 manual. Stands to reason then, that they apply to the Y385 as well. Only physical difference between the two engines is one cylinder.
Main bearing cap bolts 185 Nm (~136 ft-lb)
Connecting rod bolts 120 Nm (~89 ft-lb)
Flywheel bolts 65 Nm (~48 ft-lb)
all values are +/- 10 Nm (~7 ft-lb)
Unfortunately these are the only torque specs in my manual. For the others, you'll have to rely on a metric bolt size versus torque chart like this: http://www.dansmc.com/torque_chart.htm
Bell housing bolts don't have a torque spec, but several owners have found them to vibrate loose. LockTite is recommended.
//greg//
Greg,
Many thanks for quick reply.
Johnny P
IRANCH WOOD GRAB (A60736)
IRANCH WOOD GRAB...
DOOSAN 5K FORKLIFT  G25P-5 (A60736)
DOOSAN 5K FORKLIFT...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2004 V.E. ENTERPRISES 500 BBL FRAC TANK (A60736)
2004 V.E...
MULTIQUIP LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
2007 Ford F-750 2,000 Gallon Water Truck (A60352)
2007 Ford F-750...
