Torque Motor # ????????????
   / Torque Motor # ???????????? #1
jnaas2
Evansville, In
terramit t5
I have a 97 tc5 and want to replace the torque motor, Terra mites web site shows 64003 for this part, I cant cross reference it anyone have an actual number I can use. And specifications on motor would be nice. Thanks
   / Torque Motor # ???????????? #2
I've got an older (around 1986) T5 and was looking in the manual last nite. Here are some numbers of various parts:
Aux Pump Sperry Vickers AV1052558D20 PN 415557
Drive Motor TRW Ross MAE24-010
Valve Assy Gresen V-20-327
Transmission Sperry Vickers TA15V1022D11L
You can call Terramite and ask if there is a cross reference number for 64003. I hope this helps.
   / Torque Motor # ???????????? #3
About a year ago I bought one from Terra Corp for around
$600 after learning there was no rebuild kits available.
Got a gasket rebuild kit for drive motor, The high pressure gasket had failed and pushed out the dust and dirt gasket on the spline drive. Took it apart and replaced the seals myself, Its a simple design and there appeared to be no abnormal wear and works great
   / Torque Motor # ???????????? #5
I stand corrected I paid $800 for torque motor. A pump is $600.
Where did you get the gasket set? I decided to buy a new torque motor because my dirt gasket was blown out like yours and factory told me NO PARTS AVAILABLE.
If I have another blown dirt seal, I'll rebuild mine.
Nice to know., Thanks.
   / Torque Motor # ???????????? #6
Where did you get the gasket rebuild kit from?
2020 CATERPILLAR 938M WHEEL LOADER (A51242)
2020 CATERPILLAR...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
