Rotary Cutter topntilt with bush hog
   / topntilt with bush hog #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
If one were to buy a utility tractor with a top n tilt kit already installed and wanted to mount a rear pull type mower, would the top n tilt have to be removed? Would the hydraulic cylinders not stay in place while mowing? The other thing is if I need one or both remotes for the mower (to lift a wing or adjust height, etc.) If the hydraulic lines aren't hooked up to the topntilt cylinders, is there a problem with them?
Common sense is telling me that the kit sould prolly be removed alltogether, but I wanted some opinions becuase I've never dealt with this situation. Thanks.
   / topntilt with bush hog #2
you should probably remove the toplink, but I dont see why the sidelink would be a problem, it may move some, but it shouldn't be a big deal.
Aaron Z
   / topntilt with bush hog #3
If I don't want to use the hydraulic topping lift I just disconnect it from the implement and leave it attached to the tractor supported by a nylon strap so it doesn't clang around and hurt itself.
   / topntilt with bush hog #4
Pretty much what I do too.
As far as the hydraulic cylinders moving when disconnected, I don't think they would since they are "capped off" with the QD's (or DPOCV's) and no place for the fluid to go unless there is bypass in the cylinder itself...but unlikely.
   / topntilt with bush hog #5
Unless I need the hydraulics for something else, I don't even disconnect the hoses. I'd take off the topping lift when attaching the BH but only because it would get in the way of the seat
   / topntilt with bush hog #6
I don't think you need to remove anything for mowing unless you need the hose, as you mentioned, in which case some sort of check valve assembly would be good - always wondered if the quick connects would serve that purpose.
   / topntilt with bush hog #7
I suppose they would to a degree, not letting any fluid in or out when disconnected.
   / topntilt with bush hog #8
I should add that I like having the top cylinder on with the bush hog as it adds to the adjustability. Can't think of much advantage to the side cylinder, but can't think of a disadvantage either.
   / topntilt with bush hog #9
I don't see why, for the life of me, you would need to do anything. You're talking about a PULL type mower. I don't have a TNT but when using my pull type mower I just push the lift arms out wide and leave the toplink on. Of course the TL does have a bracket that supports it when not in use on my tractor. Sometimes I mow with the lift arms in the highest position, sometimes in the lowest. The only thing I could see needing to do is disconnect a hydraulic hose if, and only if, you need it to hook up to the mower to raise the deck.
Exactly. As was said in the opening question, it's a PULL type mower, not a 3pt hitch mower.
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
2020 ISUZU NQR (A55745)
2020 ISUZU NQR...
1979 MACK R MODEL (A53843)
1979 MACK R MODEL...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
LIGHT TOWER (INOPERABLE) (A55745)
LIGHT TOWER...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
