TOP&TILT KUBOTA
   / TOP&TILT KUBOTA #2
Lots of threads about TnT's. Do a search on them. Never know, though...someone may have actually done that swap. If you're going to find them, this is the place...
   / TOP&TILT KUBOTA #3
As long as the top cylinder and tilt cylinder have roughly the same stroke/length, there should be no problems. Perhaps the only issue will be where you take off the hydraulics and put it back. This is an area where if you go to a dealer, he may be able to get a schematic for you from the Kubota TnT kit that they sometimes install on Kubotas. Most of the Kubota TnT's use Gannon rams anyway. Hoses may need to be altered to accomodate the size differences.
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51691)
2006 iDrive...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
