top recommendations for optimizing berta rotary plow usage
/ top recommendations for optimizing berta rotary plow usage #1
TwoWheel
Iowa City, Iowa
Hand Tools
I know a big two wheel tractor with interior wheel spacing of 16-18" is ideal for operating a berta rotary plow but there are a lot of choices within that criteria.
If you were to buy a brand new two-wheeled tractor today and wanted the best overall setup for Berta rotary plow performance, what would you pick:
Grillo 110 or BCS 853?
Gas or Diesel engine?
Single or Swivel rotary plow?
Wheel size? with or without axle extensions?
Your answer will impact whether I would choose a 26" or 34" Berta flail mower but I'd like to give the nod to optimizing the plowing performance first and foremost.
Thanks in advance for your suggestions,
Jeff
/ top recommendations for optimizing berta rotary plow usage #2
You're talking a huge range of $ with those options. And it depends on how much plowing you have to do. I have a 739 and standard rotary plow. I think it works great. I dug my garden by hand for years until it got the best of me. Now I have a rotary plow. If you end up with the standard rotary plow, I highly recommend the mod by Grasshopperranch on youtube. Excellent idea. I did it and have never had a problem with a rock jam. And the soil here in New England is very rocky.
Berta Rotary plow modification - YouTube
Hi NibbanaFarm,
I expect to do a lot of plowing, in stages, over many years (converting up to 10 acres from compacted corn and bean fields into gardens and orchards).
Did you upgrade the wheels on your 739? with or without axle extensions? And do you use any supplemental weight (on engine or on wheels or on the plow itself) in order to optimize the handling, balance, and performance?
Thank you for the Grasshopper Ranch video. I'd like to ask them the same questions - in the video, it looks like they may have upgraded to 6.5"W x 12"H wheels with axle extensions and added heavy wheel weights...
I wonder if Earth Tools would make that rock jam modification if I buy this from them (I guess that they would).
/ top recommendations for optimizing berta rotary plow usage #4
I use the standard stock 5X10 wheels and ag tires. I set the wheels out to (I think) the widest configuration because that's what the rotary plow instructions said to do. I think they're about 25 inches outer sidewall to outer sidewall. More weight always makes the tractor more stable. But it also tends to sink in very soft soil and it's more effort to muscle around. Generally for soil working and mowing the tractor doesn't need the weights. At least for mechanized soil working implements. For snow moving, more weight is always better.
I think Grasshopperranch talks about his wheels in one of his other videos. Sort of remember him saying that they're atv wheels and tires, which were a lot cheaper than the BCS bigger wheels. I'm sure he'd answer an email.
As for the mod, it's very easy, all you need is a hack saw and a drill press. Or even a hand drill would work.
Thanks for your feedback.
If anyone else cares to share what they feel would be the best setup (tractor, engine, wheels, axle extensions, supplemental weights, type of rotary plow) in order to achieve peak rotary plow performance please let me know.
I read some things and think it could be a good piece of equipment to invest in and I read other things (wrestling with it, bottoming it out, flipping the whole tractor completely over, etc.) and am wondering what the best two wheel configuration would be to avoid problems.
Thanks again,
Jeff
/ top recommendations for optimizing berta rotary plow usage #6
Thanks again,
Jeff
I use a 735 with 5x10 wheels and 5" axle extensions with a Berta single plow. Not sure about optimum performance, but works well for me. My soil is predominately clay.The plow is a great little tool and would recommend the investment if your converting old field to a garden. Biggest drawback to using it is speed, your only working a small amount of soil each pass. 10 acres would be alot to turn over at 10 inches a pass.
Thanks,
Annual garden bed area will be small (<1 acre). Most of the ten acres would not be plowed. Instead, I am thinking about using the plow to prepare rows on contour and planting fruit trees into those rows...
/ top recommendations for optimizing berta rotary plow usage #8
You might want to think about the smallest model BCS rotary tiller to add to your one way rotary plow stable and I will tell you why.
The more you break up the soil the further you can throw it with the one way rotary plow. It may take you a few more passes but by using the tiller you will break the soil and in the process it will allow the rotary plow to dig deeper and throw farther and create very tall raised beds which is what you want because the tiller has broken 4 inches in the primary tillage. The more water you use or are blessed with AKA rain the more the ground will loosen up when it is being tilled with the rear tiller.
With the BCS and Grillo being gear driven through the final drive to the rotary plow, rear tine tiller and the flail mower models its case of whether you have preference for diesel or gas.
Its more a case of "where can I get help with a sick 2 wheel mule engine if I need it?".
Having a diesel will require more TLC unless they have compression release as standard equipment too as they will start hard if they are very cold(hint)-this is where the kerosene salamander comes in handy for both engine types. you can leave the salamander for a half hour and the mules engine will barely roll over and come to life like its 90 degrees out.
Dont let anyone kid you, all fuel turns to crap unless its treated and or fresh(less than 90 days old).
Use high test Premium fuel and SeaFoam due to the ethanol crap or ethanol free premium if you can get it.
SeaFoam also helps eliminate gum deposits and keeps the fuel fresh in both gas and diesel engines.
Most all diesel here has the highest cetane rating so no worries there but diesel fuel will have algae growth over time if it is not treated fuel and Sea foam helps prevent that too.
No matter what I use my salamander to warm up my engines completely to make them easier to start and to have warm or hot crankcase oil in the crankcase. A salamander certainly helps when warming up 25 gallons of cold hydraulic oil in a firewood processor for sure as well as the Honda GX340 engine it had.
With a gas engine you want to starve the fuel system-shut the tank and let it die and then open the choke and start it and let it run out again. with diesel its always a good idea to have fresh fuel and drain the tank and let the engine run it out if you are storing it for a long time-if you put a snow clearer on it you wont have to worry about storing it for long periods where you are.
I do not know if the engines Joel uses are indirect or direct injection engines and that may be an issue for you as the indirect injection engines require bleeding when they run out of fuel but the direct injection engines do not require bleeding to get the air out of the fuel system to let them start up.
The smallest kerosene salamander will do the trick for preheating an engine for you(if you do not already own one).
Spend some time thinking about the issue, talk to Joel at Earth Tools and then you can make rational decision. Just remember the more you can break up the ground the further you can throw it to make wide raised beds to create huge areas of soil that will take rain quickly and not let it spill away.
What you want to do is create a levee plowed area giving you ground that is piled on top of tilled ground that will allow root growth and moisture to sink in the ground and a rotary plow will do that for you and if you plant green manure crops you will be able to dig further down in the soil to throw it further to one side to make raised beds just like levee plow.
The other thing about a rear tiller is that it will cultivate quickly after the ground has been further broken by the rotary plow and allow the ground to absorb the rain between cultivating periods unless you want to plant a continuous green manure crop by the fruit trees .
I hadn't thought about doing primary tillage with a tiller prior to using the rotary plow but if I do that then more questions come up about the optimal setup since I'd be running the plow over looser/softer soil. I wonder what wheels on the tractor/rotary plow combo would provide for the best flotation (for example, 6.5" wide tires at low pressure or 10" wide balloon tires?)?
/ top recommendations for optimizing berta rotary plow usage #10
Don't rototill before rotary plowing. The rotary plow will do the job without using a tiller, and the loose soil will make it more difficult to get forward traction while plowing. You really don't want to overwork the soil because you destroy more soil structure with every pass. I only use a tiller to shallowly till large areas that have gotten away from me. Otherwise, I rotary plow once and use a wheel hoe to keep down the weeds.
To answer your questions -
BCS or Grillo - Either model will do the job asked. It mostly boils down to how much you want to spend and whether you like green or blue.
Gasoline or diesel - again, personal choice. Gasoline has a much lower initial investment, with much lower noise and vibration. Diesels have much better power, better fuel economy, and I just like them.
One way or swivel plow - I have a swivel plow. It's more expensive, but it allows you to only have one dead furrow, and allows you to go either direction.
Tire size - I have a pair of 5-12s. I've heard 6.5-12s are better because they fill the furrow better. I recently acquired a set of rubber hi-speed tracks, but haven't had an opportunity to try them.
/ top recommendations for optimizing berta rotary plow usage #11
Swivel plow. Especially if you're following contour lines to make some sort of swale like thing, or if you're making terraces. Making terraces, btw, on the steepest part of the slope is where I did manage to flip over my 200kg Goldoni.
Terraces I started uphill side and worked down. But I also hadn't adjusted the wheels to the correct spacing at that point. I think they were sitting at the widest setting, though this probably helped with not flipping over.
Swales I also did with the wheels not optimally spaced.
Some photos of are here: 216 farm work - Google Photos
I'll hopefully improve when I go to increase the width of the swales.
The raised bed technique is a bit counter intuitive to me, and some careful measurement/planning seem neccesary to get the beds right (which mine ended up different widths, and also some a bit curvy). It is important with the raised beds to start with a perfectly straight line and never let it deviate. Quite hard to correct deviations after the fact.
Thanks to everyone for your feedback and the helpful photos from Slovakia (looks like a nice farm and family over there!).
Currently, I see the following as the optimal two-wheel plow setup:
Grillo G110 tractor (BCS 853 does not appear to be worth the additional $700)
13hp Honda gas engine with j-bolt for engine weights (engine weights may not be needed with the heavier diesel...am still a bit tempted by the diesel's potential longevity)
6.5"x12"x23" Grillo wheels set all the way out with spacers to give an outside track width of 30" and an inside-to-inside wheel spacing of 17"
Foam-filled tires for additional weight/traction
Berta swivel plow (additional $650 over single rotary plow would be worth it for me since I would like to plow furrows on contour)
If I add a Berta flail mower to the above then I guess it would be the 34" mower in order to cover the wheel tracks, though am sure that the 26" mower would be easier to maneuver.
I'm always open to any more thoughts...
Thanks,
Jeff
/ top recommendations for optimizing berta rotary plow usage #13
Thanks,
Jeff
I disagree with bill about the tiller useage in a friendly way as I always create raised beds with my original Troy Bilt Tiller and to mix in mason sand.
Don't foam the tires, that will cost you a small fortune to do.
You can get along really well with tube or tubeless tires filled
with windshield washer fluid and a set of V bar tire chains and
you will have unbelievable traction. I have WWF filled tires on
my mule and I am glad I did it. if you have to change the tire
someday you will need to use a right angle grinder to get the
foamed tire off by cutting a slot down the center of the tread
and then cutting chunks of it away with the grinder.
Foaming the tires will ruin the chance of being able to remove them to
change the tire itself when the time comes as a foamed tire will not give
you much traction if the tread is all gone either.
You will want the engine weights especially when cutting furrows so that you
will keep the Grillo in line while cutting ground.
I appreciate your feedback but I probably won't till before I plow for multiple reasons.
The foam filling costs $145 in total and adds 40 lbs per tire.
Another option is the barbell weight hangers that cost $70 in total, plus the cost of barbell weights.
As far as engine weights, the j-bolt is designed for BCS (so I made a typo in an earlier thread) but for $92 one can get two suitcase weights for a Grillo engine which will add a total of 50 pounds. It sounds like this weight is a must for running the swivel plow...
/ top recommendations for optimizing berta rotary plow usage #15
Frankly, You're not likely to ever wear out a set of tires. I've have had BCS (mainline branded) tractors here from the 70's with the original rubber. They're more likely to rot off the machine than wear out. You can prevent that by keeping the machine inside and out of the sun. I am not one to upsell a feature that I don't believe in, and I highly recommend foam filling if the budget allows. These tires are so hard that it's hard to tell if they're flat. If you go out and use the machine with no air in the tube, you'll eventually spin the rubber on the rim and rip off the valve stem. Then you're in for a long search or ponying up around $20 for a tube, last I checked. Foam filling is expensive, but worth it in my opinion.
J-bolt is simply a bolt that is bought at a hardware store. two holes are drilled in the bumper. This will work for either brand.
/ top recommendations for optimizing berta rotary plow usage #16
I've spoken out against the need for extra weights in the past, but I've changed my mind. For my own use, extra weight isn't needed most of the time. But when it's needed, you'll wish you had it. I thought about upgrading to a new 853 and if I do it will probably be with larger, foam filled tires. I might even keep my 605 and just get the larger foam filled tires for it, knowing I can move them to a new 853 in the future. As Bill said, the tires wear like iron and I can't imagine needing to replace them unless you mow a lot of lawn or use them on pavement often. I had the exact issue Bill described above, low air pressure and the tire spun on the rim tearing out the valve stem from the tube. What a pain as you are then down for days while you search for a replacement tube. The tube I replaced it with has still had a slow leak since then that I can't find. Had the tube off several times, submerged in a tub, but no leak found. Replaced the valve insert 2 times too. Still has a slow leak that requires air every few weeks, and many times I have had it start to spin on the rim before I notice it's low. Pain in the rear.
/ top recommendations for optimizing berta rotary plow usage #17
Thanks,
Jeff
Hi two wheel. Some thoughts....suit case weights are nice, but they are either 25lbs or 50lbs. If that is the correct amount for your situation, then great. Even though J bolt can take a little longer to install, it is nice being able to "dial in" the exact weight better. I do think you will need close to 40+lbs for swivel plow on G110 Honda gas. Just sold a G110 diesel with swivel plow and it needed 30lbs front bumper weight. This number can of course change with the operator, depending upon how strong they are. I like the foam filled tires. I like the swivel plow if you are working on slopes. On flat ground I use the single plow, but if you can afford the swivel plow and you "just want it", by all means. It is great being able to dictate which direction the soil gets thrown with a lever. As to flail mower, unless you are doing a really large area, I would stick with 26". You are correct, they are easier to handle. Only scenario I would pick 34" is if cutting very large areas at one time. At first it might seem like bigger is always better, but each implement has a physical impact to the body.
Hydraulic rail grinder (A61307)
Hydraulic rail...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2016 Chevrolet...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A62129)
2019 CATERPILLAR...
Eagle Weathervane (A61569)
Eagle Weathervane...
2015 CASE TR270 SKID STEER (A62129)
2015 CASE TR270...
2022 Chevrolet Traverse SUV (A61569)
2022 Chevrolet...
