Top off the tractor fluid with something else?
/ Top off the tractor fluid with something else? #1
Sebculb
SW Costa Rica
'97 Deere 310D Backhoe
Hi everyone,
So I'm in a tough spot, popped a transaxle hose the other day, no biggie. Bought a new section of low pressure hose and 2 gals of Deere hygard oil.
Need a lot more than 2 gals, maybe 3 or 4. All utf options are far away and I have a gig tomorrow morning. So what can I finish filling it with? The gas station has 10wt or iso 68 hydraulic fluids, would this be okay? Maybe atf? I know there's a wet brake in there. JD 310d backhoe, transaxle holds maybe 6 gals total.
Or is this a retarded line of thinking and I've just gotta tell the customer I'll be late cuz I gotta drive and get more tractor fluid?
Thanks!
/ Top off the tractor fluid with something else? #2
ISO 68 is a hydraulic fluid but I'm unsure of the compatibility! It could cause problems with some seals. Are you by Golfito?
Hola! Sorta in the same corner as golfito but five hours north.
Yeah, I'm worried it'll damage the brakes if I put 68 hydraulic oil in there. Tractor fluid is designed to lubricate some stuff and allow friction in other places. Probably just gonna drive and buy the correct stuff.
/ Top off the tractor fluid with something else? #4
I read op on a couple of the numbered fluids, like 68 and I think 49 was the other one at my local farm store since I had seen them referenced in www postings but had no idea as to what they were. They seemed to be hyd. fluids, not trans-hyd fluids. Going to miss out on some additives to prevent wear........depends on what you are putting it in, how much of a gambler you are, and whether or not you will just make the change temporarily. If I had a seldom used, or soft used older piece of equipment that had one foot in the grave anyway, why worry. Otherwise.............
Thanks, I gotta bucket of utf on the way. Expensive and inconvenient but better than a brake rebuild later. This old hoe has 24k hours on it and it's my main livelihood.
/ Top off the tractor fluid with something else? #6
Most of the time anymore I buy all fluids on amazon and it is delivered in two days. Too easy.
(2) 460/85R38 TIRES W/ 8 LUG RIMS (A64280)
(2) 460/85R38...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
2007 Blue Bird All American Bus (A61573)
2007 Blue Bird All...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2014 Screen USA TROM 6090 Trommel Screener (A61572)
2014 Screen USA...
2024 JCB 35Z (A60462)
