top n tilt
/ top n tilt #1
eteagle
Illinois
JD 3300
After reading about the wonders of this hydraulic system I had installed. Now I have 3 remote hydraulic connections and controls, but questions someone may answer, please.
Can I use the 3ph quick attach that I have been using with blade and box scraper? Is there any advantage?
What are uses available for the extra hydraulic?
Thank you.
Ernie
/ top n tilt #2
<font color=blue>Can I use the 3ph quick attach that I have been using with blade and box scraper? Is there any advantage?</font color=blue>
Seems to me the quick attach would still work the exact same way and have the exact same advantages as before. The only problem I could see is if the cylinders were physically large enough to get in the way of the quick hitch. Maybe I'm missing something though....
<font color=blue>What are uses available for the extra hydraulic?</font color=blue>
I would use the 3rd one for any implements that have hydraulics. A box blade with hydraulic scarifiers would be great to have but $$$. A rear blade w/ hydraulic angling would be nice too. I'm sure there are more implements, maybe a stump grinder or chipper, but a box blade and rear (scraper) blade would be the two that interested me the most. Sounds like you already own those two (w/o hydraulics) though.
--Brad
