Top Link...what is it for?
   / Top Link...what is it for? #1
dty
New Jersey
Kubota 7610
I am new to this tractor stuff. I have a 7610 and just bought a rotary cutter. Can someone please explain to me what the top link is for and how is the proper way to use it? /forums/images/graemlins/confused.gif
The Kubota manual breezes over the subject and the Rotary Cutter manual doesn't mention it at all.
Thanks in advance /forums/images/graemlins/smile.gif
   / Top Link...what is it for? #2
It is used to set the angle that the implement needs to function. On a rotary cutter it is used to set the cutter at the proper angle to the ground when mowing.
oops... /forums/images/graemlins/blush.gif maybe that was a dumb question.
   / Top Link...what is it for? #4
Don't feel bad. I actually asked what a "CUT" stands for.
Sheese, now THAT was a dumb question.
-Terry
   / Top Link...what is it for? #5
I guess they figure a buyer has some experience or usage is intuitive.
Your tractor manual should discuss the 3 Point Hitch to a degree. The two lower links (draft links) actually do the lifting part. The upper link (top link) helps stabilize the implement your are using when hooked to the upper connection of the implement you are using.
For example, your rotary cutter should have two pins approximately 3/4" in diameter and about 4" long. The are horizontal. Your lower links (with the ball eye bushings) connect here.
There should be an upper bracket that probably swings. The upper (top) link connects here. For use, you thread out the link so that bracket on the cutter can follow the ground contours. For transport, you tighten (shorten) the upper link as much as possible...by hand. There is a jam nut on the threads of the upper link closest to the tractor end. I just run it up by hand, but I don't transport my implements too far. Once tightened, you can raise your cutter, but don't raise it high enough to have the PTO shaft riding on the front end of the cutter.
Also, by tightening or loosening the upper link, you can raise or lower the front end of the implement somewhat. For a rear blade, this makes for a more or lesser aggressive "bite" in the soil.
To hook up the cutter, have the tractor engine off with the key in your pocket (in YOUR pocket!). Hook the lower links to the pins on the cutter and install the lynch pins in the holes (on the cutter pins) outboard the tractor's lower links.
Then, hook up the PTO shaft. If you look at the tractor's PTO, you'll see a groove machined circumferentially on the PTO. The implement PTO shaft will have a mechanism that locks in that groove. The PTO shaft will have a spring loaded button or ring on the tractor end "U" joint. Depress that button (or rotate the ring) and push the "U" joint on the tractor's PTO. Once the splines are lined up, let go the button (or ring) and push toward the tractor until you here the shaft's locking mechanism lock into place. Pull back on the shaft to ensure it's locked in place.
Rotary cutters don't have front wheels, so I suggest you have some kind of lever handy to jack it around a bit to get everything lined up.
Now, this may sound complicated, but with a few tries it'll take you less time to rig up an implement then it did for you to read this.
Good luck!
now that was an answer! Thanks Roy
   / Top Link...what is it for? #7
Roy, I'm glad you gave such a detailed tutorial about the pto attachment and the way it locks in the groove. The hookup is critical for safety. We've all heard the stories about pto's.
Five points for Roy /forums/images/graemlins/laugh.gif
   / Top Link...what is it for? #8
</font><font color="blue" class="small">( Don't feel bad. I actually asked what a "CUT" stands for.
-Terry )</font>
<font color="red">C</font>ute <font color="red">U</font>gly <font color="red">T</font>ractor.......??????? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Top Link...what is it for? #9
David,
I too have a 7610 and am looking at rotary cutters. What kind of cutter and what size?
Donald B.
   / Top Link...what is it for? #10
I asked MChalkey (an "ex" TBN fella so full of wisdom and other saucy things, it's too bad we are not blessed with much of his spew anymore) the same thing. I also spent a period of time figuring what FEL, MMM and PHD meant. I thought a FEL was something folks back East must use that we don't use out here, you know for dragging logs or cutting trees. MMM was some kind of new candy and PHD was the level of intelligence needed to understand half the crap people were talking about. Now top link, I knew lots about that. I even corrected O'l Bird on the TnT acronym once. Folks were calling it Tip N Tilt. I quickly nipped that in the bud. TnT is not dynamite, it's Top and Tilt. Now if you have a hydraulic Top Link, thats DYNAMITE! /forums/images/graemlins/cool.gif Thats <font color="blue"> Mr RaT </font> to YOU!
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
J and L Cargo Express Shadowmaster Enclosed Trailer (A51039)
J and L Cargo...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
