Top Link Setup
   / Top Link Setup #1
Kubota 2350
Platinum Member
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
When setting up an I Match 3 point quick hitch which hole for the top link at the tractor gives you the greatest height when it's lifted, the top hole, the center hole, or the bottom hole?
Thanks in advance.
   / Top Link Setup #2
Just thinking about the geometry of it, I think the bottom hole will make the top of the I Match tilt forward more at the top of the motion, making the rear of the implement higher. The front implement pins will lift to the same height no matter what.
Bruce
   / Top Link Setup
Thanks Bruce,
I'll give that a try tomorrow, (more play time) :cool2::cool2: it was in the center hole. I moved it to the top and it didn't change much, I really want to get my rear blade up as high as possible when in the up position.
   / Top Link Setup
Couldn't wait until tomorrow, went out to the barn and moved it to the bottom hole and I gained about 6-8 inches more lift on the blade.
It's where it needs to be now.
Thanks again
Truck Wheel Fenders (A51692)
Truck Wheel...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
19?? Asphalt Roller (A52377)
19?? Asphalt...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
(INOP) 2005 BRODERSON IC80-3G 9 TON ROUGH TERRAIN CRANE (A51406)
(INOP) 2005...
2011 Freightliner M2 106 Ambulance (A51692)
2011 Freightliner...
