Toplink top link question?
   / top link question? #1
mattellis2
Bronze Member
so i bought a new top link for my 3ph this last weekend. my original was bent by the previous owner, and i finally got around to needing to adjust it, so i picked one up. it looks like the one in the picture below:
my question is this: how do i install the little bar used to crank the turnbuckle body? it has little dimples on it that prevent it going into the hole drilled through the body. i figured i get some suggestions here prior to hitting it with a big freakin' hammer!
thanks!
-matt
   / top link question? #2
I hit mine with a medium sized hammer.:D
   / top link question? #3
Thats all there is, just beat it in with a hammer. Just make sure after you get it through the first hole, you line it up with the second hole before smacking it again. (experience talking here!)
Then if it looks like it might still fall out again, take a chisle and peen the hole closed again, and you may be able to open the dimples on the bar. I didnt, and mine hasn't gotten lost yet.
Keith in SC
   / top link question? #4
Once you get it through and centered, you could weld up each side.
don't you leave it loose so you can slide it back and forth? longer lever=easier to turn!
-matt
   / top link question? #6
-matt
Concur. I've got at least half a dozen of them. After tapping the rod through, I've never ever lost one. The fact that they slide back and forth definitely gives a torque advantage to a heavy load on the threads.
//greg//
   / top link question? #8
Matt, your question brought a smile to my face as I'm sure it has with all the others who have done this before. Another interesting thing in your post was that the former owner bent the previous toplink. How do you do that?:confused: The only way I can figure to do that would be with a disc cultivator or rotary cutter and the toplink adjust too far out. Then, if you went over a rough spot, there might be enough leverage to bend a toplink. My wife had an old International with a bent toplink when we got married. She didn't bend it and I could never figure out how that happened either.:)
   / top link question? #9
By the picture in your signature I am pretty sure you can think of a few more ways to bend up just about anything on a tractor :)
   / top link question? #10
Matt, I'm so glad you asked that question. I just replaced my first top link and had no idea how to get the rod in. Now I know. :) I love this forum!
378812 (A51573)
378812 (A51573)
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2014 Ford Transit Connect Cargo Van (A55852)
2014 Ford Transit...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2022 BMW X7 xDrive40i AWD SUV (A53424)
2022 BMW X7...
