Top link fro CK30
   / Top link fro CK30 #1
TForan
Bronze Member
Mi
Kioti CK30HST
I bent my top link and I need a new one. Is it a Kioti part or is it a generic part I can get other places.
Thanks!
Tony
   / Top link fro CK30 #2
Generic; just match the min/max length and the "ball" end pin size and you should be good to go.
   / Top link fro CK30
Thanks,DH
I picked one up at TSC.
   / Top link fro CK30 #4
I notice the CK30 stock toplinks are wimpier than the
$20 generic aftermkt toplinks I have purchased. Go
figure.
   / Top link fro CK30 #5
</font><font color="blue" class="small">( I notice the CK30 stock toplinks are wimpier than the
figure. )</font>
That was something I noticed on most of the new tractors I tried when I was first looking for a new tractor. Like you said, go figure.
John
   / Top link fro CK30 #6
Shows what I know. My top link is heavier than the one that was on the old Ford. I use a couple for different implements to avoid adjusting all the time. How do you bend one?
   / Top link fro CK30
</font><font color="blue" class="small">( How do you bend one? )</font>
I can bend anything!
I had the threaded part out quite a ways and must have bent it when I was backing up. The TSC link is heavy duty and it's only 18 bucks.
   / Top link fro CK30 #8
Should be easiest to bend (buckle really) when the TL is extended all the way and resisting a large compressive load like pulling a subsoiler and hitting a root.
Backing into a low stump with a boxblade should pull on the toplink and not bend it. That is a good way to bend your lower 3ph arms and stabilizers though.
   / Top link fro CK30 #9
The CK30 stock toplink is only 3/4" diameter at the
bottom of the threads. I have seen many buckled ones;
I am sure this happens using a box blade and hitting
a rocks or roots. A hyd toplink is usually 1.125"
diameter.
45012 (A48082)
45012 (A48082)
2005 INTERNATIONAL 7400 STAINLESS STEEL DUMP BODY (A50046)
2005 INTERNATIONAL...
16FT BUMPER PULL SPOOL TRAILER (A48992)
16FT BUMPER PULL...
HYDREMA 912HM ARTICULATED DUMP TRUCK (A50458)
HYDREMA 912HM...
2017 FORD E350 16FT BOX TRUCK (A50046)
2017 FORD E350...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
