Top link cyl advice
   / Top link cyl advice #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
I'm looking to put a hydraulic top link on and I have two questions so far.
1.My factory top link measures 18" closed and about 36" extended.The only cylinder I have found so far is 17.5 closed and 27.5 extended.Should I be concerned about the shorter extension? Surplus Center Item Detail
2.What are sae#8 ports in english?.I'm used to 1/4 pipe etc.What is a good hose id for this?.
   / Top link cyl advice #2
Only you can tell what extension you'll need for your top link. The full length of 36" sounds like a lot, but if you need the full length you're going to have to have to settle for a longer closed length. The closed length will be stroke plus 7 1/2" and open length will be closed length plus stroke. So for a 36" length you'll need a stroke of 15" and you'll have a closed length of 22 1/2".
Surplus center is a little confusing when they call things "SAE." The ports on that cylinder are what is called "o-ring boss." On the surplus center website, if you look under "fittings" they have them listed under just "o-ring." The sizing of the fittings is for the hose they go on, so the "SAE 8" fitting goes with an SAE 8 hose. SAE sizes are in eighths of an inch, so SAE 8 is a half-inch hose. The actual size of the fitting is 1/4" bigger than the hose, so a SAE 8 fitting is 3/4" in diameter. The thread is just straight 16 thread-per-inch, so you'll sometimes see SAE 8 called 3/4-16. Clear as mud?
For a top link, you don't need the capacity of a 1/2" hose. A 3/8" hose will be less expensive, and will slow the cylinder down somewhat which will make it easier to make fine adjustments.
Finally, that cylinder has 1" eyes. If your tractor has a category 1 hitch you want 3/4" eyes. Surplus center sells a bushing that reduces it to 3/4". Surplus Center Item Detail
   / Top link cyl advice #3
Hose and fitting dimensions are in sixteenths of an inch. A -8 hose is 8/16 of an inch, or 1/2".
A SAE or any other fitting(except for pipe) is the exact size that it is labeled. NPT is larger thread than what is labeled. This is because NPT is used mainly for pipes, which are measured on the outside, hose and fittings are measured on the inside. However much larger the NPT thread is than it's fitting size is however thick the metal for the thread is. Larger size NPT fittings may be 1/2" or more larger than it's stated fitting size.
Whenever you hear of a port referred to as SAE, it is straight thread o-ring. There is also SAE 45 degree flare which is very similar to JIC. They even interchange except for -6 and -12.
   / Top link cyl advice #4
You're right, I got a little sloppy there. Which is a terrible thing to do with hydraulic fittings, because while the actual fittings are rigidly standardized, the terminology is all over the place.
What I should have said is that the SAE dash number is the inside diameter in 16ths ( not eighths, don't know why I said that). For SAE-8 o-ring boss the male fitting has an outside diameter of 3/4" and they are sometimes referred to as having a 3/4-16 thread, which is correct -- but somewhat confusing.
The full name for these fittings is "SAE J514, Straight Thread O-Ring Boss."
Here are some of the names they go under:
Discount Hydraulic Hose calls them "Straight Thread O-Ring"
Surplus Center calls them "SAE" or "O-Ring"
Northern Tool calls them "STOR" (short for Straight Thread O-Ring)
They are also known as "O-Ring Boss" or ORB for short.
Calling them just "SAE" is particularly unfortunate because there are two other popular SAE standards, 45-flare and 37-flare (also called JIC).
Here is a link to a chart showing actual sizes: http://lib.store.yahoo.net/lib/fittingsandadapters/threadprofiles.pdf
Here's what I don't get: the SAE STORB fittings seem to be the most popular for cylinders and valves, and least popular for hoses. What's up with that?
   / Top link cyl advice #6
bones1 said:
Thanks guys, I think:confused:. Ok.Tell me if I have picked the correct fittings for this sae 8 cylinder .Surplus Center Item Detail
Yes, the -8 ORB, or SAE, or STOR(all the same) will screw right into your cylinder. Will also give you your -6 pipe thread. Also, no tape or sealant on this type of pipe thread. Never sealant on a pipe swivel. Pipe swivels seal on the internal surface, not on the threads.
Quicksandfarmer- STOR is popular on valves as it provides an effective seal onto a flat surface. Not popular on hoses because you would need either the male or female end to swivel, like on a pipe thread swivel crimp fitting. This requires an o-ring, which always, overtime, leak. Also, it is not good to screw a hose directly into a port. You run the risk of damaging the port whenever you disassemble anything. I would rather change a damaged fitting going into a valve than a damaged valve.
   / Top link cyl advice #7
You mt want to take a look ate the CCM toplinks with the double piloted check valve. Also the CCM Hyd. toplinks have chromed and hardened rods for longevity of use.
   / Top link cyl advice #8
I don't know how you guys can sell them for the price you do. I can't make that cylinder for what you guys charge to buy it.
   / Top link cyl advice #9
You won't have the right stuff until you buy from CCM.;) Cylinder, hoses, fittings, everything. No reason to look anywhere else.
After three years, my toplink works as good as it did new; solid as a rock.:)
   / Top link cyl advice #10
Bones these are the items that I ordered to outfit my Montana 3040 with a toplink. The 45 degree adapters work well and you still have room to turn a wrench, those 90's you showed may not give you enough room to get a wrench
I still have issues with it that I have not figured out. The cylinder retracts when great pressure is applied and then returns to the original position. Others on TBN suggested it was air and that makes sense but I have not gotten it out yet
2024 JOHN DEERE 1025R LOT NUMBER 163 (A53084)
2024 JOHN DEERE...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
20ft x 20ft Steel Carport (A51573)
20ft x 20ft Steel...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT6DH646717 (A51572)
2013 Dodge Charger...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
