top dead center
   / top dead center #1
tmar04
YM 276
I am planning to replace valve stem seals on my YM2500 (3T80) with head on. What is easy way to tell when piston is at, or near, TDC, to preclude valve from dropping into cylinder? can't stick straw into injector hole because of the 'precombustion chamber'. got to be an easy way. thanks to all.
   / top dead center #2
The best way I found was to rotate engine by hand. When compression is felt (rotating will get hard), Push down one of rockers, for each cylinder, one at a time. 2 of the 3 cylinders will not affect ease of rotation. 1 cylinder will cause rotation to get easier and you may hear air excaping from cylinder either thru exhaust or intake, it depends on which rocker you push on. Then you know that that cylinder's piston is on its way and close to TDC.
On my 3T80 there are marks for 1,2, and 3 TDC, if yours does to, that will help.
Be advised that this proceedure is how you adjust lifters too! And is how I determined I had poor compression in 2 cylinders, prior to my rebuild. While rotating engine it never got difficult to rotate by hand, until #3 cylinder came up to TDC. Implying that 2 of the 3 cylinders had poor compression.
   / top dead center #3
Another easy way is with the valve cover removed, rotate the engine until you see the 2 valves rocking..(exhaust valve will be closing and the intake will start to open, technical term is valve overlap). Then turn the engine another 360 degrees and you are close enough. When the exhaust valve is closing at overlap, the piston is pretty close to TDC, the intake valve starts to open as the piston moves down to suck in more air.
Work your way to the other 2.
Good Luck!
   / top dead center #4
Hey Rock, what lifters are you talking about. All diesels I worked on had basically a solid lifter riding on the camshaft. No adjustments.
If you are talking about adjusting the valves...well then nevermind. :D :D
Rob
   / top dead center #6
I use a bicycle spoke through the combustion chamber cone...a gentle probe will indicate the piston travel height.
Once you've pulled the valve keepers it may be necessary to keep compressed air in the cylinder to reassemble the seals, springs and keepers...not sure as I haven't done it that way.
Mark
   / top dead center #7
Air usually not needed on a diesel. Flat top piston and a flat head. This is my Kubota which probably is the same as most small 2-3-4 cylinder diesels.
Rob
   / top dead center
Rock2610D, thanks for tip on TDC on 3T80 eng. Mine has the same three marks on pulley, 1-2-3. If I line up the #1 mark with the pointer, does this mean #1 piston is at TDC? Sure would simplify matters. thanks.
   / top dead center #9
Its a 4 stroke engine. Up once for compression, down once for power stroke, up once for exhaust stroke, and down once for intake stroke.
I believe that when the cylinder # is aligned with the pointer its either in the TDC of compression stroke or exhaust stroke. Not 100% sure though so if I were you I would double check, because its a 3 cylinder and I could be wrong, as firing order is 120 degrees apart.
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
2025 Future 72in Log Grapple Skid Steer Attachment (A53421)
2025 Future 72in...
PALLETS OF HEAVYEQUIPMENT (A53843)
PALLETS OF...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A52377)
2005 Ford F650 SVI...
2007 STERLING T/A DUMP TRUCK (A51406)
2007 STERLING T/A...
