top cat 2 hydraulic link
   / top cat 2 hydraulic link #1
m7040
Elite Member
Frederick maryland
Kubota M7040, MF 203 industrial, ZD331, RTV 1100 , Kubota Minix excavator, Unimog 404
Just installed one of Mark Carter's toplinks this weekend. Works like a charm. Now this cylinder has check valves built in to prevent drift in position. Question: Is it possible to backfit check valves to the loader cylinders and has someone out there done this??
   / top cat 2 hydraulic link #2
Yes it is possible and no I have never seen it done. The exact DPOCV on the CCM cylinders are not available here in the USA. You can buy similar ones but they are larger and would probably present a problem with mounting. In any event you would need two of them. The bottom line from my perspective is that it's not practical.
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
2022 DYNAPAC CA3500D SMOOTH DRUM ROLLER (A51242)
2022 DYNAPAC...
2016 Ford Escape 4WD SUV (A50324)
2016 Ford Escape...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
1994 Prevost Liberty Coach Motorhome (A51694)
1994 Prevost...
