Top and Tilt
   / Top and Tilt #1
MikeyB
Parker,CO
JD 3320
Does anyone have a Top and Tilt kit? I saw it in the JD parts catalog and thought it would really be something to control your rear implement from the seat. I am a little confused though. It seems to me you would need two Power Beyond kits to obtain 4 hose ports if thats possible. I have seen 1 control next to the rockshaft to control the center link tilt but what about the tilt feature of the three-point arm? I am sure this is way beyond my price range at the moment but I can dream can't I?:D
Thanks for any info,
Mike
   / Top and Tilt #2
No power beyond required, you will need the electric diverter though which will put two sets of remotes at the rear of your tractor. You then turn on the diverter switch and your loader stick will then control the rear remotes. The lever next to rockshaft is for your third service which is one more set of remotes at the rear. I just installed that on my tractor, already had the diverter as mine had TNT before I got it.
Darrin
   / Top and Tilt #3
maybe a dumb question but have always wonder about this.
Will this then give you any amount of down pressure?
roger
   / Top and Tilt #4
This will not give you any down pressure. Down force is all gravity regardless of TNT.
   / Top and Tilt #5
thanks thought so, gravity and the weight of the imp. hum. I have a 4110 with rear blade would like to have more ump. Guess better put on more weight.
thanks
roger
   / Top and Tilt #6
I've got just the top link because I rarely need to tilt any of my implements. Mine is Cat II and was pricy but it is worth it's weight in gold when it comes to hooking things up. With Pat's hooks and the top link I can hook up faster than I can with my other tractor that has a Speedco Quick Hitch.
You can get the TNT at Carter & Carter a whole lot cheaper than at JD.
Hydraulic top link, Top-N-Tilt, Side link
Mike
   / Top and Tilt
My tractor is still under warranty so I was worried about going with someone else. with your tnt what did you use for a valve? My JD dealer says I can get a valve control that goes next to my rockshaft control. Supposedly the valve is already there with my loader joystick. I just need the lever to control it but I suppose I'll need the Power Beyond kit to power the tnt cylinders.
Alot confused,
Mike
   / Top and Tilt #8
Mike,
What your dealer is talking about is the third service and yes your tractor has it already, you just need to install the kit. It is very easy, I just did it myself. The first and second service is your loader joysick. When you add the third serive it puts one set of rear remotes on the back of your tractor. If all you want is to run the hyrdaulic top link, that is all you need. What a diverter does is add two rear remotes to the back of your tractor and a switch in the cab/or fender. When you turn the diverter on the first and second service is diverted from the loader to the rear. With TWO remotes you can run a Top and Tilt. If all you want is the top link, the third service is the way to go, way cheaper and you can use it to run a grapple latter also. You will NOT need power beyond unless you add a Hoe or something else that needs an open connection to the hyrdaulics. Hope this explaination makes sense.
Darrin
   / Top and Tilt #9
No down pressure? What's this?
Notice that my rear tires are about 3 inches off the ground. It will do that with the box blade while you're working if you push it a little too far.
   / Top and Tilt
NDAWind,
Thanks for the explanation. That finally makes sense to me!
Regards,
Mike
MMS MS36C (A53316)
MMS MS36C (A53316)
2018 Ford Fusion Hybrid Sedan (A55758)
2018 Ford Fusion...
Skid Of Metal T Posts (A50775)
Skid Of Metal T...
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A54865)
2006 Volvo VNM...
Parker Gravity Wagon (A50775)
Parker Gravity...
Miller Spectrum 500 DC Plasma Cutting System (A55851)
Miller Spectrum...
