toothbar: should I bother welding it?
   / toothbar: should I bother welding it? #1
Mackinac Joe
Near Midland, Michigan
JD 2320, JD 2038R
Hi Guys,
My new 7-tooth Markham toothbar is just begging to be installed on my 53-inch bucket. It came with a couple small spacer plates that appear to be designed to be welded to the inside of the bucket.
I'm sure this would reduce the chance of reaming out the bolt holes. But is welding the plates really necessary?
I'm no welder (it's been 20 years since I've welded anything and I was a novice then), and I'd have to either pay to have it done or rent a welder.
Should I bother welding it, or just bolt it up? Your advice?
Thanks,
Joe
   / toothbar: should I bother welding it? #2
I just drilled through the sides of the bucket and used washers for spacers.
Can't say I've seen any wear or obrounding of the bucket mounting holes yet.
   / toothbar: should I bother welding it? #3
The plates are probably just spacers. I wouldn't weld any additional plates. Your chances of wearing out the bolt hole is next to none IMHO. I can't tell any wear in mine.
   / toothbar: should I bother welding it? #6
I would not weld them. I've had mine off a few times already. I can back drag a lot better with the smooth bucket and get better results back dragging with the bucket than I do with my scraper. (Thanks Eddie for the idea!)
   / toothbar: should I bother welding it? #7
I've only bolted mine on. I do take them off for different tasks. I would suggest bolting them on until you determine your own use and preference.
   / toothbar: should I bother welding it? #8
I would not weld the spacers ....;)
Chris....:)
   / toothbar: should I bother welding it? #9
I did not weld mine. Nice company to deal with.
2019 Dodge Journey Crossroad SUV (A53424)
2019 Dodge Journey...
2019 Ford F-250XL (A53314)
2019 Ford F-250XL...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
2020 Chevrolet Express (A53314)
2020 Chevrolet...
