TOOTHBAR ADVICE .... AGAIN
   / TOOTHBAR ADVICE .... AGAIN #1
tc35dforme
Platinum Member
New England...Central MA
TC35D/16LA
I know this topic ranks among the most posted topics here on TBN, but I have a bit of a decision to make and would like to solicit some opinions.
My TC35D has a heavy duty 72" bucket with a bolt on cutting edge ( in addition to the small welded on edge or lower bucket lip ).
My question....do I get a toothbar that fits over the whole arrangement or remove the cutting edge and install the toothbar ? I plan on leaving the toothbar on for 85 % of the warm season and removing it completely for snow. By removing the bolt on edge, I save $ 75 on the toothbar and also don't push the teeth that extra 1" - 2" below the lower edge of the bucket. By leaving it on, I gain the strength of the 1/2" edge, but I am concerned about the teeth being so low. Should I be ??
What have others done with the NH bucket ??
Thanks in advance.
   / TOOTHBAR ADVICE .... AGAIN #2
Hi TC35DFORME,
I recently installed a bolt on toothbar on my 35D, 72" HD bucket. However my cutting edge was not a bolt on. I got some info off TBN from a company in NY (I can look up if you're interested). I ordered the heavy duty version, and am happy with it despite the close to $400. tag. The bolt on version enables me to take it off when using the bucket for snow removal. Good luck.
   / TOOTHBAR ADVICE .... AGAIN #3
I recently put a woods bolt on toothbar on my 66" bucket and it works great. I did take it off for the winter.
Dan
   / TOOTHBAR ADVICE .... AGAIN #4
I got a heavy duty bucket, with the bolt on toothbar for my 60" bucket...the tooth bar has never come off....my snow removal is on gravel road and I just keep the bucket level...I don't need to get it down to pavement. But for everyrthing else I can't imagine not having the tooth bar - uprooting brush, moving logs, etc.
Chas
E-Z Trail 672 Head Cart (A50514)
E-Z Trail 672 Head...
Yamaha Golf Cart (AS IS) (A50774)
Yamaha Golf Cart...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
2016 Ford F-450 Ext. Cab Knapheide Stakebody Flatbed Truck (A50323)
2016 Ford F-450...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
