Front-End Loader Tooth bars / Toothed bucket / bolt-on teeth
   / Tooth bars / Toothed bucket / bolt-on teeth #1
dgeesaman
Harrisburg, PA
New Holland TC45DA
My bucket has a flat straight edge. When I'm loading fresh manure with it, the hay makes it difficult to "grab" a load and tip it back into the bucket. (The hay decomposes in older manure - it's the fresh stuff loaded with hay that's difficult)
I like the simplicity of a tooth bar but I'm concerned it will get in the way of dumping the material in the dump truck. To load it I have my loader at full height and I can only tilt the bucket down slightly when the truck is nearly full.
There are about (6) 3/8" holes already in the leading edge of my bucket. I have to wonder if bolting on a simple tooth to each one could work.
Finally, I know I've seen fairly large deep buckets with teeth on them. The one EA sells is about 3x my budget, but if I could find a used one would be great.
I'd like to hear your opinions.
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
2019 FORD F-250 (A52472)
2019 FORD F-250...
Ford Tractor (A50120)
J and L Cargo Express Shadowmaster Enclosed Trailer (A52748)
J and L Cargo...
2020 EZ-GO Elite RXV Electric Golf Cart (A50324)
2020 EZ-GO Elite...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
