Buying Advice Toolcat
   / Toolcat #1
thecarman
arkansas
2015 toolcat 5600
Any suggestions on a grapple for the toolcat? It will be used for cleaning up brush and such on my property. The spear grapple looks (bobcat brand) like crap in my opinion and is over 3000.00. It doesn't have to be heavy duty. I like the ones that will sit fairly flat on the ground so I can pick up limbs and small debris.
   / Toolcat #2
Check these guys out.
wildcat attachments.com
(866) 811-5319
   / Toolcat #3
Be careful not to go too big, I have a 72" Virnig twin cylinder skeleton grapple that will cause problems with traction on hills due to the weight. A smaller version would be better and more useful when cutting up the branches and limbs up.
   / Toolcat #4
This would work good or maybe even gooder. :D
It has a larger opening than the original Wicked Grapple.
Single Lid Root Grapple
433215-toolcat-eta-slrg-2t-jpg
   / Toolcat #5
I like independent closing grapple. I use an industrial fork grapple. A little heavy at 900lb but works good. I tried the farm grapple.. single cylinder but it didn't fit my needs.
2013 UTILITY VS2DX 53FT DRY VAN TRAILER (A51222)
2013 UTILITY VS2DX...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A51039)
2012 Freightliner...
2022 LEGUAN 190 SPIDER LIFT (A51242)
2022 LEGUAN 190...
Pump Jack with Battery (A49461)
Pump Jack with...
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
Komatsu WA270-8 Articulated Wheel Loader (A49346)
Komatsu WA270-8...
