Toolcat wheel hub bearing.
   / Toolcat wheel hub bearing. #1
DaveBittel
Bronze Member
Toolcat 5610
Has anyone replaced bearings in a Toolcat wheel hub? Parts lookup only shows complete assembly from Bobcat. I getting some play and sounding a little rough when I replaced an axle.
   / Toolcat wheel hub bearing. #2
Which series? I just redid my B model axle and spindle bearings, wasn't too bad.
   / Toolcat wheel hub bearing. #3
Don’t pay the dealer price!,
A hub for a Chevy Colorado 04-07 4x4 is an exact fit. Cheap and available at any auto parts store. just pop off the speed sensor wit a screwdriver.
   / Toolcat wheel hub bearing. #4
Will it fit the F Series that Dave has?
I’ll have to check that out!
   / Toolcat wheel hub bearing. #7
I just saw a video showing a guy replacing his tierod ends with Moog #ES80643 pieces for a huge savings. They also come with zerks!
   / Toolcat wheel hub bearing. #8
Just a note on the above video I posted. I see the OEM tie rod ends have a round plug pressed into them instead of a zerk. I just tapped the plug sideways a couple times and grabbed it with diagonal pliers and popped it out. A normal 1/4" zerk will screw right in....I did all 4 in about 45 minutes.
2019 TAEKUCHI TL8 SKID STEER (A51242)
2019 TAEKUCHI TL8...
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
New Swict 60" Skidloader Bucket (A50774)
New Swict 60"...
2013 MAGNUM TRAILER GENERATOR TRAILER (A50854)
2013 MAGNUM...
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
