Toolcat cruise not working
   / Toolcat cruise not working #1
Phillip B
Savannah mo
Toolcat 5600 D-series
Hello, never used a forum! Bear with me! Anyone ever have cruise problems with their toolcat?
   / Toolcat cruise not working #2
Hi Phillip,
I might suggest you start by check to see if the unit is displaying any error codes. Your manual will tell you how to check for codes through the dash controller. If you do not have a manual you might check the small 'reference guide' that is tethered to your interior firewall in between the seats as I believe it is outlined there as well. If you don't have a manual you can post the error code here and I will look it up for you. It is important that you include which series (A, B,C,D, & F?) Toolcat you have.
It's not throwing any codes, Bobcat says its probably the button in the control panel,1200$ I traced the wireing, all plugs were good, guess it could be the throttle position sensor , it's a D series, just under 1000 hours,probably put it in the shop this winter,, thanks for the reply! I guess this is an uncommon problem,,,just those gremlins!!
2011 TRAIL-EZE  TE80HT48 HYDRAULIC TRAIL (A50854)
2011 TRAIL-EZE...
2007 BIG TEX END DUMP TRAILER (A50854)
2007 BIG TEX END...
Stihl KM 130R String Trimmer and Edger (A49461)
Stihl KM 130R...
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
Case Ih 2388 Combine (A50514)
Case Ih 2388...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
