toolcat 5600 service
   / toolcat 5600 service #1
jrock18
dorothy nj
ford, bobcat, cat,
Had a couple questions about a toolcat that my buddy owns, i notice the only way to get to engine is under the bed. What happens if you run it out of fuel and need to crack an injector or just say its not running? Is there a way to get the hydraulic bed up to work on the engine? thanks john
   / toolcat 5600 service #2
Yes, there is. I bungeed the hydraulic bed control lever to the lift position and then raised the bed with a come-along and strap that is looped over a well-supported truss chord in my shop. As soon as the bed is lifted, there's a safety device that can be swung down on one of the hyd bed lift cylinders.
   / toolcat 5600 service #3
If you were to run out of fuel, there is a 'bulb' between and under the seats that you can access from the engine compartment that will allow you to purge any air from the system without 'cracking' the injectors. I would really watch the fuel guage as you will be 'pumping' the bulb for quite sometime to purge the air...
yea i guess that would work, just seems like a bad design. Think they should of installed a manual lift pump that would allow you to lift the bed. thanks for the input though ill try that if i ever run into a problem.
   / toolcat 5600 service #5
On my "D" series, the primer bulb is accessed from the outside engine cover on the passenger's side. It's very easy.
If the battery goes dead and you can't jump it for some reason you can actually remove the side cover between the driver's side cab and the rear fender to gain access to the battery itself.
DEWFPO
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2001 INTERNATIONAL 2574 6X4 (A51406)
2001 INTERNATIONAL...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
