toolcat 5600 2006
/ toolcat 5600 2006 #1
paulfarmall
Wesst Bridgewater MA
2006 5600 toolcat
Hi I have a machine with no electric power to the dash panel
I have checked the main fuse at the battery and test all the fuses in the fuse box and under the dash panel. The fuse box has no power to some of the fuse and other do. it seams that the ignition part is not turning on. tested the ign switch it has power and tested that it is getting to the dash panel, so I have ignition and crank signal to the panel. And there is are two red wires that are 12 pos to one of the panel plugs. It would seam that the panel has a problem but the repair manual is a little vage on that.
Paul
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
(1) 20 Yard Roll Off Dumpster and (1) 40 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
2004 TRAILMOBILE 102" X 36' VAN TRAILER (A64277)
2004 TRAILMOBILE...
2023 Big Tex 16GN 102''x40' Gooseneck Trailer (A64127)
2023 Big Tex 16GN...
2023 Bobcat T64 (A64126)
2023 Bobcat T64...
Cattle Feeder (A65640)
