Toolbox?
   / Toolbox? #1
3pedal
Brighton, CO
2015 Branson 4720h
Has anyone found a good solutions for putting a small toolbox on your Branson? Got a 4720 last year, and would really like someplace to carry some pliers and a couple pins at least on the tractor.
   / Toolbox? #2
I made a bracket that goes from the "window" mount bolt over to the mirror mounting bracket.
   / Toolbox? #3
Bolted a ammo can to that. I hate drilling holes on a new tractor! None required for this.
   / Toolbox? #4
I've picked up a can and am going to make my bracket. I will put on the right side since the loader controls block easy access on that side of the tractor. I have a 4520R
   / Toolbox? #5
Thought about that, the brake pedals where in my way. The location hasn't bothered me.
   / Toolbox?
That should work. Of course I have a few ammo cans, but not that size. Time to start working on the bracket and looking for the can.
   / Toolbox? #7
I found a rectangular wire basket (O'Reilley's as I recall) measuring about 12x3x4" high with a couple of handles on it that fits nicely between the right door and the hyd lines to the joy stick. It also fits on either side of the seat on the floor, but I like it better by the door....easy access and out of the way. Otherwise you might look at welding a metal box like TSC sells for about $20 in red or green to your FEL vertical bracket.
I'm looking for a good spot on my 2400 to add one as we speak....and a beverage holder.
   / Toolbox? #8
I'm planning to replace the right step with a big ammo can. Drill three holes, shot of paint, remove step, bolt on new toolbox. I'll post up a pic when I'm done.
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
Unused Delta Crash...
WB Mower (A50120)
WB Mower (A50120)
2025 AGT MX-MRT14 (A50123)
2025 AGT MX-MRT14...
1997 Dynapac CC142 14 Series Double Drum Roller (A52384)
1997 Dynapac CC142...
2015 JOHN DEERE 544K WHEEL LOADER (A51406)
2015 JOHN DEERE...
