Took a Test
/ Took a Test #1
Rat Rod Mac
I recently took a Civil Service test for a janitorial job at the local school. Some of the questions seemed quite different from what I'm used to doing. Normally I just dive right in and do what ever is neccesary but this time there was a right and wrong answer and of course after it's all over they just tell you your score and you never get to see which ones you missed and why. So, I don't know if this is the proper place to discuss this or not and maybe it's more related to the women, but here goes,,,. One of the questions was,, How do you properly empty a wastebasket? There were four answers to chose from. Two are always way out in left field, but the other two are always close. So the two answers to the above question are 1) turn the wastebasket over and dump the contents into a larger container. 2) while holding the basket with one hand, use the other to pull the contents out and into a larger container.
Another question, Do you hang a mop up with the mop head up or down?
Another one, do you clean gum off of the gym floor with a putty knife or a rag soaked with alcohol? I've got more but I'm out of space. Thanks RRM
/ Took a Test
Took a Test part 2
Another one, when cleaning a window do you,, 1) go around in circles 2) go back and forth.
Another, When waxing a floor do you ,,, 1) put the wax on heavy and mop it around 2) put on two or three thin coats.
These questions may sound dumb to some of you guys, but I'm used to farm work and didn't know there was a right and wrong way to wash a window. But a test is a test and they are trying to eliminate someone. I'm not picking on the ladies, but I'm sure you know more about this than I do. There were also questions about wire sizes, plumbing, lifting with cables, ladders, hand tools, etc,etc. and I felt comfortable with these, but the proper way to clean sure threw me a curve ball. Thanks all. RRM
/ Took a Test #3
Re: Took a Test part 2
#1 so your butt doesn't wiggle side to side... thats what they tell instructors in the military.
I'd say #2, #1 would make a mess, get splashed on walls, cause waxy build up out at the edges/corners of the floor. Again, drawing on the vast skills I learned in the military :D
Charles
/ Took a Test #4
Well, RRM, I hate to tell you this, but you failed the TBN posting test.:rolleyes: ;) :D
You can keep writing at the bottom of the posting box and it will just scroll down. If you want to keep posts short, you can submit a short post and just reply to your own post rather than starting a whole new thread. I hope you did better on your janitorial test than you did this one.:eek: :)
My answers?
1. Dump the trash. You will not get me to stick my hand into something like that without know what is at the bottom of that trash can. I'll dump it and look at the contents afterward.
2. Scrape the gum with a putty knife. You don't know what alcohol might do to the finish on the gym floor. A piece of ice to harden the gum and careful use of the putty knife would be my choice. What would happen if the alcohol melted the gum and also the finish? Oh my! Big mess...
3. Clean windows with straight strokes downward and finish wipe side-to-side.
4. Hang the mop head down. If you put it head up, it will drain downward onto the handle and whatever you are hanging it on.
I don't know if my answers are correct, but that's how I would answer all of them.
/ Took a Test #5
It would be interesting to know their 'correct' answer as I have seen people do it both ways. I would go with 'dumping' as well. The reason is needle sticks, if a diabetic or other needle user does not properly dispose of their needles you can reach in there and get stuck. Then you get to spend a few months wondering how your various blood tests are going to come back.
/ Took a Test #6
I merged the 2 threads.:)
/ Took a Test #7
My answers?
Jinman- My only difference is #4. I hang the mops with the mophead p. When you hang a mop you have already wrung it out. If you hang it mop side down it gets in the way of the brooms and dust pans. Plus if you hang it mop side up you kind of flip the srings to the front so you can lay it more flat against the wall. Who knows the correct answers anyway.
Correction, washing windows. You start at the top and go side to side working your way downwards. The reason is the cleaning product will run down by gravity so you don't really do to much up and down strokes, perhaps a few at the end of the cleaning.
/ Took a Test #8
Hiya,
Finally a post where I can use all the stuff I learned working nights as a custodian at a high school to pay my way through electrical engineering/computer science degrees.
OK, first thing you have to realize there is a vast difference between commercial cleaning and what you do at your house. (for example, you don't break out a garden hose to wash your bathroom or spray the walls of your kitchen down with bactericide.)
#1 Trash can: You flip the trash can over the bucket, push the can as far into the barrel as hard as you barrel to compact the trash already in the barrel, pick it up and hold it open palmed on both sides, take one hand and slap the side of it hard to knock the trash loose and let if fall into the big barrel, flip the can on the rim of the big barrel and use your putty knife to get out any remaining stuff. never use your hands to touch trash, you will be sorry if you do.
#2 Gum on a gym floor: Use the putty knife. (If you need to at all. In the colder months, you can just flick it off with the edge of your boot. (the cement is cold enough to harden the gum.) Gym floors are really tough, a putty knife wont hurt them at all. If your wet mopping with cold water, flip the gum into the mop water, it will sink to the bottom and when you dump the bucket it will go down the slop sink drain. If your dry mopping, leave it on the floor and push it along, the dirt will stick to it and it won't stick to the floor again.
#3 Windows: Always done with a window squeegee set. One for washing (looks like a paint roller but doesn't roll, called a mop), one rubber blade. wet the mop, start at the opposite lower than the hand you are holding it in, go around the edge, then using long sweeping strokes cover the entire window, to dry, start at the same corner as before but end up at the opposite lower corner.
#4 Mops: Mops are never "hung" unless they are "dry mops" (the type to sweep the dust off the floor, they are wide and they swivel) Wet mops are always draped over the wringer of the mop bucket to dry. That way you never have to look for one or the other, they are always together.
#5 Floor Waxing: 3 to 5 very thin coats will give the best wear and shine. Before you strip the old wax, draw a rough pic of the room and mark the highest wear areas, strip the old finish, rinse, rinse, rinse and rinse more, ( the more you rinse the old gunk off, the brighter the floor will look) Apply a thin coat to only the high areas you marked on your paper, let dry an hour, go over the areas again and expand them by 50%, let dry 2 hours, apply the third coat to the entire room keeping a foot away from the walls or any other structure, let dry overnight, next morning apply a very thin coat over the entire room keeping 3" from the edge, let dry for a day, next day, apply the thinest coat right to the edge, let dry 2 or 3 days before you put desks back or else the sliders will rust to the floor and your supervisor will not be happy.
OK, as you can see commercial cleaning is a lot different than home cleaning but after a few years of a school department cleaning, you can whip through the toughest stuff in a house in minutes. :D
My 38.4 cents,
Tom
Reynolds 18yd Dirt Pan (A64047)
Reynolds 18yd Dirt...
6'x14' Lawncare Utility Trailer (A64047)
6'x14' Lawncare...
2013 CHEVROLET SILVERADO 2500HD (A63569)
2013 CHEVROLET...
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59911)
2012 INTERNATIONAL...
2002 International 9200i Truck (A61307)
2002 International...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
