Took a picture mid project then a couple more
   / Took a picture mid project then a couple more #1
cperky
Middle TN
John Deere 1025r with 120r front end loader, Hustler zero turn mower
I was taking a break from today’s project. Walked out on my deck. Took the above picture. I wish I had a couple of “before” pics but I didn’t think about it till I took a break. I removed an old flowerbed that was here when I moved in a couple years ago. It Contained two crape myrtle trees. Each was 15/20 feet high. I hated to take it down but it was just in the way. Anyway thought I’d share a few picks even though I started taking pictures mid project. Below is some of the roots I pulled out of the ground. I used my kens bolt on hooks a good bit today. Had to use chainsaw to cut roots from stump. Then pulled up stump separately from roots.
End result !
   / Took a picture mid project then a couple more #2
Good job!
That chainsaw set down on the lawn like that makes me nervous. You could have 300 acres to turn your tractor around and somehow one of its tires is going to cross paths with where you set the chain saw down. Just does. Chainsaw have the gravity pull of a black hole.
Good job!
Good point about the chainsaw. Something ill keep in mind.
   / Took a picture mid project then a couple more #5
👌 Does make project kinda with right equipment.
   / Took a picture mid project then a couple more #6
Good job!
SO TRUE !!!!
   / Took a picture mid project then a couple more #7
Chainsaws also have the ability to affect your memory. Put one in your loader and two minutes later you will scoop up a load of dirt or if you are lucky just dump the saw on the ground before you pick up the dirt. DAMHIKT.
Doug in SW IA
   / Took a picture mid project then a couple more #8
Looks nice, I carry my chainsaw in the bucket all the time but I do worry about forgetting it’s in there. Cperky, if you lived closer I’d be happy to help you next time. I’d even bring my tractor to. I wouldn’t actually help you, I’d just run your saw over for you, you know twice. The first time going forward, the saying ”what was that sound”. Then backing up and running it over again when I investigate the sound.
   / Took a picture mid project then a couple more #9
Nice job Mr. Cperky.
Interesting how something like a crepe myrtle is beautiful at 4 or 5 feet tall...and can grow to be a nuisance at 10 or 15 feet tall!
Regretfully, I too have a lot of projects where I wish there were some good "before" photos...
Most people go through life as critics and don't appreciate the effort required and the improvements made!
   / Took a picture mid project then a couple more #10
Doug in SW IA
Or it falls out and you run over it at speed, EXCITING
Crate of New Hydraulic Hoses (A47384)
Crate of New...
20' Inline Feed Bunk (A50515)
20' Inline Feed...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
CFG Industrial QK18R (A50121)
CFG Industrial...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
1991 Great Dane 48' Reefer Trailer (TITLE) (A50774)
1991 Great Dane...
