too much play in power steering...how do i adjust?
   / too much play in power steering...how do i adjust? #1
Charlie22
iron,mn
ford 3600
Just purchased1979 ford 3600. diesel 1000 hours Has been used on sod farm, equipped with turf tires. There is way too much play in the power steering. How do I adjust?
   / too much play in power steering...how do i adjust? #2
Are the pins tight?
correction: there is too much play in the power steering box. how do I adjust?
   / too much play in power steering...how do i adjust? #4
have you checked power steering fluid level? if it was low / just received and previous owners filled it up without your knowledge. you may need to simply move steering wheel fully left till ya hit a stop and then fully right till ya hit a stop. just repeat this a few times to help clear out any air that might be in the hoses / cylinder. then recheck power steering fluid.
other words air trapped in the system, and is causing the play, and ya just need to work out the air by fully turning steering wheel in both directions till ya hit a stop.
   / too much play in power steering...how do i adjust? #5
Possible broken spring washer on top of control valve
Gary
1995 BEALL TRAILER FUEL TRANSPORT PUP TRAILER (A52472)
1995 BEALL TRAILER...
City of Lakeland (A51691)
City of Lakeland...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2000 Ford F-150 Pickup Truck, VIN # 1FTRX17W7YNA75070 (A51572)
2000 Ford F-150...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
J and L Cargo Express Shadowmaster Enclosed Trailer (A52748)
J and L Cargo...
