too much oil problems?
   / too much oil problems? #1
fluffhead31
Colchester, Vt
NH TC35A w/ 16LA FEL
I changed the oil and filter on my NH35A, and overfilled. It's well over the full line on the dipstick. What should i do:
a) Ignore it
b) Run it w/ the dipstick out and let some oil spill out.
c) remove plug and drain some.
Thanks!
   / too much oil problems? #2
Drain out the excess...
Too much oil can cause foaming (air in the oil) which results in poor lubrication.
Better a quart low then a quart high...
   / too much oil problems? #3
yup... loosen drain plug and drain some out.
   / too much oil problems? #5
an 8$ fix plus a car ride to solve a 1 minute with a wrench and bucket problem? um.. ok.... ???
   / too much oil problems? #6
$8 plus a trip to HF and the problem ISN"T solved. 1/2" ID tube won't fit down a TC35 dipstick tube. OP is out $8, wasted trip, has a useless transfer pump, and still needs to bend over and drain some oil out the old fashioned way.
   / too much oil problems? #7
even better!
   / too much oil problems? #8
I would take off the oil filter and drain it. Reinstall, start, then shut down and check. If needed repeat. Most filters will hold about 1/3 of a qt and this will be the less messy way of solving this issue.
Chris
   / too much oil problems? #9
Chris
Filter is mounted horizontally and holds maybe 3 ounces of oil. Makes a giant mess when removed. I spent 15 years servicing these tractors. Pull a drainplug. There really isn't a better way.
   / too much oil problems? #10
He could use the pump for his auto tranny fluid in his truck. In the past, prior to syn fluid fills, I'd suck out (through the dipstick tube) and replace a quart of auto tranny fluid every time I changed the engine oil. Did it do me any good? Guess so. Never had a bad tranny and didn't have to mess with the periodic drop the pan sloppy mess.
Mark
2012 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52705)
2012 CATERPILLAR...
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
JOHN DEERE 8R310 TRACTOR (A54756)
JOHN DEERE 8R310...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2015 FREIGHTLINER...
