Too much freon???
   / Too much freon??? #1
Complete Turf Care
Veteran Member
South Louisiana
2022 Kubota Grand L6060 (no loader), 2017 Kubota Grand L6060, 2011 Kubota L5740 HSTC-3, 1997 Kubota M4700
I have a 2011 Kubota L5740 that I have owned for several years. I bought it with about 250 hours and it now has about 1300 hours.
My air conditioner belt recently started to squeal when the compressor kicked on. Belts were tight and fairly new.
Googled it and thought it may be the compressor clutch going bad. Brought it to a mechanic and he agreed, so we ordered a new clutch from the local Kubota dealer. (About $700 with shipping)
Later today they called and said it's not the clutch, it was too much freon in the system. The took a little out and now it works fine.
My question is.....how can I get too much freon in the system? I know very little about AC systems, but I've never heard of that. It's great if that was the problem, because I have about 20 or 30 hours of work coming up for this tractor and it sure is hot right now. And I like saving the $700 for the clutch.
I know that no one has worked on the AC since I've owned the tractor.
   / Too much freon??? #2
I'm glad to hear they didn't install the clutch which saved you $700 but I'm not buying any part of it. The fact mechanic would equate a slipping belt to the clutch tell's me he doesn't know the first thing about air conditioning and should not be working on them,,,,,,period. Too much Freon? Maybe,but that doesn't cause the belt to slip. That it no longer slip's after removing some Freon might be true but there has to be another problem if that's true. I would be more inclined to think when belt was changed earlier it was the wrong belt and wore enough to begin slipping. Let us know if it cool's as well as before.
   / Too much freon??? #3
I would be curious if they evacuated the system and weighed in the correct charge? The ONLY way to determine it had an overcharge would be to weight the recovery cylinder before and after evacuating the system.
   / Too much freon??? #4
How did you decide slipping belt equaled bad clutch in the first place? The fact that it was applying enough resistance to slip the belt obviously meant the clutch was good.
   / Too much freon??? #5
   / Too much freon??? #6
The OP didn't say anyone had changed the belt. In fact, he said no one has touched the AC, except the guy who let out some Freon. He did say the belt started squealing recently.
   / Too much freon??? #7
im with you guys, I wouldn't want that guy working on my tractor and the AC, I just had my 5088 AC system serviced and the guy took out just over 2 lbs - replaced some orings and a seal in the compressor and put back in around 4 lbs or something like that. his has some kind of metering system on it and it does it in .1 decimals on his machine - so like if you want it to put in 2.1 2.2, 2.3 etc....that is what it puts into the system
it also reads that as it evacuates the system and it has pressure gauges that show what its doing also - I know I overcharged my truck and it didn't slip the belt it shut the compressor off - they will shut off the compressor in a low or high pressure condition for the Freon amount I don't think it causes the compressor to lock up but I guess it could if the pressure sensor was defective and not kicking it out
   / Too much freon??? #8
Back in my AC&R Technician days we had two types of service techs; diagnostic technicians who could analyze a system, and parts changers who kept changing parts till they happened on the fix. Those guys often overlooked the second problem and it still wasn't right. It was fun following those guys and fixing their screw ups. Poor customer was stuck with a double bill and the first was usually higher. I would give them a diagnostic review so they could try to recover their first bill.
Auto type ACs have very little, if any, storage for excess refrigerant (Freon is a brand name of DuPont) so it is easy to overcharge if you do not have the data on quantity required and the precision metering device to add only that. It may quit soon if the real problem was a leak and air got into the system. Air or other gases in the system are non-condensebil at system pressures, take up refrigerant space, and raise head pressure. Excess head pressure will stall the compressor and squeal the belts. This is only one possible problem. There are others. You do not learn AC service by reading a book or stumbling around.
Ron
   / Too much freon??? #9
He did say belts are fairly new so that mean's belts had been changed.
   / Too much freon???
I googled something like "ac belt squeals when compressor starts" and most of what I found was that belts were loose or worn. I didn't think that was my situation. I found a few discussions that said it could be the clutch.
Yes, the belts were changed about 300 hours back when I had some work done on the exhaust.
This mechanic is about 70 years old and knows his way around tractors. I doubt he has had any formal AC training, but he has been around. He said he checked the pressure and it was too high, so he let a little 'refridgerant' out and it seemed to solve the problem.
I guess I will find out when I get on a job with it........
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2003 International 4300 Dump Truck, VIN # 1HTMMAAL83H562953 (A51572)
2003 International...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2018 Jeep Grand Cherokee Multipurpose Vehicle (MPV) (A51694)
2018 Jeep Grand...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
